Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-10-2011, 12:36 PM   #1
Superswid's Avatar
LEt's PLay "Name that Pipe"
What the hell is this pipe sticking out of the ground for? It used to have an empty electrical outlet screwed on top of it which I removed. There are no wires or anything going into or out of this thing. Yet I can't pull it out of the ground because it won't budge. Does this serve some kind of purpose or can I just pull/dig it out?
Superswid is offline   Reply With Quote
Old 12-10-2011, 12:49 PM   #2
Conduit for the wiring but it was never finished?
housegsx is offline   Reply With Quote
Old 12-10-2011, 01:47 PM   #3
Crusty Old Dude
Big Stud's Avatar
If you just want to get rid of it, dig down just below grade and cut it off and cap it. then you can just give it a decent burial
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 12-10-2011, 01:49 PM   #4
Superswid's Avatar
what would I cap it with? And is it really necessary to cap it or can I just cut and bury?
Old 12-10-2011, 03:47 PM   #5
joed's Avatar
If it is an electrical conduit it could run inside you house somewhere. If you don't cap it, water could flow into the house. I would do at least some investigation to see where it might go.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-10-2011, 03:53 PM   #6
Superswid's Avatar
Well it has always been un-capped and exposed. I cut it down and then stuffed a long rag down the top and then buried it.
Old 12-10-2011, 04:03 PM   #7
A proper cap may be purchased at any hardware store. A little glue and you would be safe.
However, now that the pipe opening is below ground level its conceivable that the rag would rot away and that you would have a river of water running into your electrical panel.
If this happened, you would then have a major problem on your hands.
Old 12-10-2011, 06:17 PM   #8
JOATMON
ddawg16's Avatar
See if you can force air down it....if it flows....it's comeing out somewhere....if not...then the other end is blocked...
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 12-11-2011, 10:40 AM   #9
Superswid's Avatar
too late, already found a nice cap at Lowes. Cut it down, put some water-proof silicone inside the cap and placed it over the hole than buried it. I'm sure it was an electrical conduit that was not in use because as I said, it had a box on top without any outlets wired in. Just an empty box sitting screwed into the top.
Old 12-11-2011, 01:14 PM   #10
Crusty Old Dude
Big Stud's Avatar
I know it was not in use. That does not mean it doesn't come into your house somewhere. You did well to put a cap on it,
The Following User Says Thank You to Big Stud For This Useful Post:
Superswid (12-11-2011)
Swing set play area frame out... 68MHJCs Building & Construction 10 05-14-2013 01:32 PM
Bug free kids play area sippinjoes Pest Control 7 11-02-2011 05:51 AM
Childrens Play Structure staining gone wrong nobeginnerluck Painting 3 09-11-2011 06:08 PM
Backyard Play Area for Kids sippinjoes Landscaping & Lawn Care 8 06-30-2011 10:29 AM
plug and play jacuzzi or buy from friend? pollybest Appliances 4 09-23-2009 08:08 AM
