Lennox Furnace G10 Won't Kick On - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 01:18 AM   #1
Question
Furnace was running fine until today. The pilot lite will stay lit but the furnace won't kick on. Any suggestions what the problem could be or what I could do I would appriciate any help. Thank You
LakersGirl24 is offline   Reply With Quote
Old 01-10-2011, 07:01 AM   #2
Rewards Points: 6,652
What lights are flashing on the circuit board down below, and how are they flashing? Also, have you checked the air filter to make sure that it is clean, and that there is fuel to the unit (ie gas did not get shut off).
Old 01-10-2011, 08:21 AM   #3
Try taking the cover off the front. See if the Exhaust and intake are plugged. If you take the cover of and it kicks on they are
14701NYtileman is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ HVAC 3 10-30-2010 08:24 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 06:52 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
