Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-30-2011, 05:46 PM   #1
LED Pool Bulb Voltage Question
Hey guys,
I ordered a par38 style LED multicolor pool bulb with remote on the internet to replace a halogen fixture thats white only. My pool guy says its wrong because the voltage to the fixture needs to be 12 volt and the bulb says ac 100v-250v. He says if he runs 100v to the pool that could shock someone if there is an issue. I believe him, but wouldn't this bulb that draws 8.5watts of power work on a 12 volt socket too? I'm not very confident in my pool guy...
Thanks!
Drywallhelp is offline   Reply With Quote
Old 11-30-2011, 07:21 PM   #2
joed's Avatar
If the bulb says 100-250 volts, that's what it needs. Find one that is rated for 12 volts.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-30-2011, 07:25 PM   #3
Did you look at the socket? These bulbs are not interchangeable.
Ron
B. Franklin 1759
Old 11-30-2011, 09:35 PM   #4
Yes, I have that 2 bulb halogen socket, he was going to replace it with a 12 volt par 38 style socket so this bulb would work. However, I don't think it will even though I emailed him the specs and he said it was good. I don't think he read it carefully.
Old 11-30-2011, 09:51 PM   #5
find a new pool guy.
you cant run a 100-220v filament on 12v, and you CANT modify a pool lighting fixture (you said he would change out the base?)....that certainly would delist the fixture at a minimum.
if you are certain you have a 12v niche, then order the correct bulb. in any case, 12v or fiber optic are preferred for saftey.
jcrack_corn is offline   Reply With Quote
Old 11-30-2011, 10:06 PM   #6
Made a few angies list inquiries already!
voltage testing question...... serrano Electrical 8 10-05-2011 05:53 AM
Landscaping Lights tied into pool sub-panel? Dwillems Landscaping & Lawn Care 2 09-06-2011 11:53 AM
Pool Pump with NoFlo Question waterwoman Plumbing 0 05-27-2010 11:19 AM
Replace pool light DONRILEY Electrical 5 07-20-2008 05:51 PM
low voltage lighting question please.. melissadurante Electrical 1 03-02-2008 01:55 AM
