-   -   Leaving eaves open (http://www.diychatroom.com/f2/leaving-eaves-open-158085/)
John G. 09-26-2012 05:19 PM
Leaving eaves open
1 Attachment(s)
I have a 1940's bungalow in Boston, my eaves were boxed in but squirrels keep getting in! I opened them up and cleaned out everything they brought in and found a few dead ones. My question is can I leave them open and just clean them up or is that a bad idea? Any help would be great.
Attachment 58015
joecaption 09-26-2012 05:27 PM
You have a mess there. Far better to knock out the blocking and add vented vinyl soffit.
If it was mine I would use Certainteed vinyl cove moulding and beaded soffit.
That would do to things keep the old house look and give you a place to lock in the last piece of siding that looks like someone tryed to face nail and it's all buckeled on your house.
John G. 09-26-2012 06:34 PM
The blocking you see is one piece running all the way to the top of the roof. I am getting the house resided, I am just confused whether close them up with mdf and cut holes and put vents in or leave them open. I know air flow is important for the attic and it is finished but old and don't want the squirels back, the ate through the siding once. Thanks for your help
joecaption 09-26-2012 08:33 PM
MDF for outside trim:eek:
Then replace the old soffits with alumium soffit.
Get rid of the over hanging tree limbs so they can not get back up there.
hand drive 09-27-2012 11:37 AM
If you do not install a ridge vent the newly installed soffit vents will not really work well. Critter control will be easier with new heavy duty soffit vents also.
notmrjohn 09-27-2012 11:56 AM
There are many open rafter eaves, I dunno if it is style of your 40's bungalow. That blocking has to go if it reaches under side of roof and you want ventilation from under eave.. Stretch screen wire vertically back past outer wall across rafter bays down to house wall behind siding, may need some narrow blocking up top between rafters to fasten screen to. Cover screen with 1/4" hardware cloth under siding, screen door molding over top edge of cloth screen. Plenty of ventilation, no bugs, no rodents.( Sqweerell just too hard to spell)
Cut back branches if scraping roof or house, but the skwe.... tree rats gonna come across on them wires anyway.
