Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-07-2009, 10:47 AM   #1
Default leave window unit in window?
how many of you leave your window ac units in over the winter?
I've never done it before, and am nervous i will lose too much heat.
joetab24 is offline   Reply With Quote
Old 11-07-2009, 11:04 AM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
I've never left my window unit in a window, not a great seal
I have built a window unit into the wall
In the winter I had an insulated trimmed box that would fit over it from the inside
I tried an outside cover (material) - but too think
The metal casing of the AC itself will transfer cold into the house
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 11-07-2009, 11:14 AM   #3
thanks for the reply dave,
i am finding it's harder harder to get help lifting the dam@ thing out. my pop helped me a few years ago and we dropped it (a older unit i've since replaced); he, as he always is, was in a rush (another thread for another board ...).
Old 11-08-2009, 12:12 AM   #4
Please, take it out! trust me, a month of Ice Cold will convince you.
Think about having to deal with it in even colder, nastier weather!!
I would like to suggest getting a new, LIGHTER air conditioner. The cost today is so much better than it used to be, and we don't need the huge monsters we used to have to buy.
My HVAC brother proved this to me years ago, and I'm so glad he did.
I'm renting right now, and it had a very heavy air conditioner when I moved in, and it was the first thing I took out. The new one is so light that I put it in myself, and have had no trouble with it at all, AT HALF THE BTU's! Cheap too!
Because my husband and son are handicapped, and can't help, I have to think of things like this. If possible, and you decide to take it out, try to pick up a lighter air conditioner.
You won't regret it, and you won't freeze this winter either!
Sheila4467 is offline   Reply With Quote
Old 11-08-2009, 12:41 AM   #5
Scuba_Dave's Avatar
That's why I built mine into the wall
Too heavy to move every year & I don't like to block the window/light
Old 11-08-2009, 10:07 AM   #6
I had one in an upstairs room years ago and just got tired of moving it, I made a box using soft foam that fit snugly over the ac. Two slabs of foam covered the space on either side of the window. It worked very well. I ended up leaving the two slabs on year round. If this is a bedroom you might be able to cover the foam with cloth to make it look better.
Rege
RegeSullivan is offline   Reply With Quote
Old 11-08-2009, 04:41 PM   #7
I only keep the 1.5 ton in, since it is too large to remove, plus the window was modified when the older unit that this one replaced was in. When ever we get around putting in Central Air, the window will be replaced with a newer Double Glaze.
gregzoll is online now   Reply With Quote
More On This Topic
Repair corroded lines and in your car air conditioner when repairing the accumulator; learn how in this free DIY auto-mechanic video from our expert in automotive AC repair and maintenance. Read More »
Getting up from your seat constantly to change the temperature on a portable or window air conditioner can really be a drag. It's reminiscent of the days before remotes, when you had to get up from the sofa to change the channel on the television. That's... Read More »
Hi! I'm Brian a mechanic at Rony's Car Pros in Culver City, California. I am here on behalf of Expert Village to talk to you about fuel efficiency. Air conditioning can use from 10 to 20 percent of your fuel efficiency. So when you are on the freeway and... Read More »
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
Room additions are an exciting remodeling project. It's nice to anticipate the enjoyment of extra space in your home. But you want the room to be comfortable year round for maximum enjoyment. There are several ways and means to accomplish this. Read More »
Need help w/squealing screeching ac window unit ohiogirl HVAC 1 07-12-2009 08:01 PM
Nasty smell in my Samsung window unit deejohnson HVAC 4 06-15-2009 11:02 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 07:11 PM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 12:07 PM
RO size vs. window unit size, new construction BigJimmy Building & Construction 3 01-02-2008 09:34 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
