Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-07-2007, 09:30 AM   #1
Leaky window (sill)
Hello, we just moved into this townhouse build in the mid 90's a few months ago and have noticed water pooling in the window sill during heavy rain. We have two windows in that location, approx 1ft separating them.
The second picture is a close up of the corner of the sill. Obviously air is getting in due to the bubbles. I have inspected the outside and could not see anything obvious.
Any advice?? Thanks
sable is offline   Reply With Quote
Old 10-07-2007, 02:55 PM   #2
Leaky window (sill)
If you open the window do you see water sitting between the window and the screen on the bottom?
Can you take photos of the exterior of the window and siding?
redline is offline   Reply With Quote
Old 10-07-2007, 03:34 PM   #3
Leaky window (sill)
thanks for the reply, there is no water pooling between the window and screen. All drainage holes are open and clear.
I will try to get some photos of the exterior
Old 10-07-2007, 03:37 PM   #4
Leaky window (sill)
It sounds like the water may be getting in behind the siding/window from above then traveling down to this point. The exterior photos may reveal more.
Old 10-07-2007, 04:33 PM   #5
Leaky window (sill)
Redline, I think you are right, we went on the roof and poored water on top of the flashing and sure enough the water began to enter from both the top corner, running down to the bottom corner of the sill
There also appears to be some "gaps" where caulking should be, so we are going to purchase the appropriate caulk and see what we can do
Old 10-08-2007, 11:50 AM   #6
Leaky window (sill)
Is the water getting in from the roof area or from around the window ?
Is there a gutter above this window?
Shrink Film Window Insulation miserlou General Discussion 10 11-24-2008 07:19 AM
Window Sill flashing? sandyman720 Building & Construction 6 08-06-2007 10:24 PM
Condensation on Metal Window Frames: Should I Caulk? xquercus General Discussion 6 06-29-2007 10:24 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Replacing the Sill on a Double hung Window Marshall Building & Construction 2 03-30-2007 12:18 AM
