-   -   Leaky window (sill) (http://www.diychatroom.com/f2/leaky-window-sill-12165/)
sable 10-07-2007 08:30 AM
Leaky window (sill)
2 Attachment(s)
Hello, we just moved into this townhouse build in the mid 90's a few months ago and have noticed water pooling in the window sill during heavy rain. We have two windows in that location, approx 1ft separating them.
The second picture is a close up of the corner of the sill. Obviously air is getting in due to the bubbles. I have inspected the outside and could not see anything obvious.
Any advice?? Thanks
redline 10-07-2007 01:55 PM
If you open the window do you see water sitting between the window and the screen on the bottom?
Can you take photos of the exterior of the window and siding?
sable 10-07-2007 02:34 PM
thanks for the reply, there is no water pooling between the window and screen. All drainage holes are open and clear.
I will try to get some photos of the exterior
redline 10-07-2007 02:37 PM
It sounds like the water may be getting in behind the siding/window from above then traveling down to this point. The exterior photos may reveal more.
sable 10-07-2007 03:33 PM
Redline, I think you are right, we went on the roof and poored water on top of the flashing and sure enough the water began to enter from both the top corner, running down to the bottom corner of the sill
There also appears to be some "gaps" where caulking should be, so we are going to purchase the appropriate caulk and see what we can do
redline 10-08-2007 10:50 AM
Is the water getting in from the roof area or from around the window ?
Is there a gutter above this window?
