Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-24-2011, 10:21 PM   #1
Leaky foundation at the chimney.
I'm sorry if this has been discussed before but I couldn't find it in the searches.
I have a leak in my foundation where the chimney joins it. It's cracked on both sides. The foundation is only 4ft high. I need to repair these leaks and I really don't have a lot of money. I want to do it right and I'm not afraid of hard work. I already dug it all up to expose the cracks. I just need to know how to patch the cracks so that it won't happen again. Most of the water in the pics came in on the last rain after I had it dug up.
Any help would be greatly appreciated.
Rick.
roost4u is offline   Reply With Quote
Old 09-25-2011, 07:54 AM   #2
Cracks can usually be sealed with urethane caulk or similar. If the cracks are large, first pack them with foam backer rod. All availabale at home, hardware stores for a few dollars.
Old 09-27-2011, 02:29 PM   #3
Going out now to clean all the loose stuff off. Any more input on this repair is greatly appreciated.
Old 11-09-2011, 09:37 AM   #4
Did you get this fixed? Other than some mortar joints, where was it leaking? Did you see it in the basement? What is that black drain pipe?
mjzraz is offline   Reply With Quote
Vinyl Siding - What to do about stepped foundation and chimney? mlowrie Building & Construction 3 06-10-2011 12:05 AM
h/e furnace, leaky chimney, and more moral_hazard HVAC 1 04-26-2011 06:47 PM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Leaky foundation jools Building & Construction 7 04-18-2008 08:58 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing 6 03-07-2008 04:12 PM
