Leaking Toilet - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 09:31 AM   #1
Leaking toilet
HI. I'm wondering if any1 can shine some light on my problem.
I have an ideal standard loo that leaks when it's flushed from between the Cistern. I've replaced the "Doughnut" washer and the close coupling plate as it was corroded but it still leaks. Any ideas??
Pauly15 is offline   Reply With Quote
Old 10-01-2011, 09:29 PM   #2
Rewards Points: 5,336
Are you speaking about a toilet that's 2 separate pieces, a bowl and a tank connected by a 2" metal elbow? Or is this a 2 piece with the tank on top of the bowl?
Ron
B. Franklin 1759
Old 10-02-2011, 03:03 PM   #3
It's 2 separate parts. Cistern & pan.
Old 10-02-2011, 03:58 PM   #4
Yes, I get there are 2 separate pieces. The question I asked was which setup do you have.
The solution to the problem is based on the setup you have, not that you have 2 pieces.
How old is this toilet?
Ron
B. Franklin 1759
Old 10-02-2011, 04:03 PM   #5
2004 the toilet was installed. It's a 2" drop valve, if that helps??
Old 10-02-2011, 04:19 PM   #6
Sorry, it doesn't. Seems you're not in the US and use different terminology.
Posting a photo will help along with the manufacturer and model number.
Ron
B. Franklin 1759
Old 10-02-2011, 04:24 PM   #7
It's an idea standard toilet.
Old 10-02-2011, 04:30 PM   #8
Never heard of an idea standard toilet.
Sorry, not familiar with that part.
What country are you in?
Ron
B. Franklin 1759
Old 10-02-2011, 04:42 PM   #9
From the U.K
Old 10-02-2011, 04:50 PM   #10
Rewards Points: 6,652
If the tank is leaking, that means that a gasket is missing. Take it all apart, and put all new parts on it at this point. Over tightening of the plastic sleeve can be one, missing the gasket between the bolts and the tank, and the metal plate and the tank can also be the problem.
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 02:47 PM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 09:03 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 05:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
