Leaking Threshold - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 06:25 PM   #1
Leaking threshold
The threshold of my 16' garage door lets water underneath it and into my garage... Mostly when the storm winds are stronger. Was thinking of putting down a system called the tsunami threshold.... Anyone heard of it? Any opinions or advice?
stoked91 is offline   Reply With Quote
Old 03-19-2012, 07:09 PM   #2
Rewards Points: 1,092
Any way to better grade (ie, steeper) whatever is outside, or is it concrete or asphalt?
Old 03-19-2012, 08:27 PM   #3
Can't really... It's the concrete driveway...
Old 03-19-2012, 10:43 PM   #4
figgered that. good luck w/ the water damn.
Old 03-19-2012, 10:49 PM   #5
Rewards Points: 13,748
There was suppost to be a step of at least 1/2 between the aprin and the garage slab, then the aprin was suppost to be sloped away from the garage.
If it was not done then I see no way a dam is going to do more then act as a funnel as the water runs down the door.
Old 03-19-2012, 11:11 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
maybe a slot drain?
Tom Struble is offline   Reply With Quote
Door Threshold question jakeclev Windows and Doors 1 03-17-2012 03:14 PM
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 01:20 PM
Should I chance removing this threshold? rosemonster Building & Construction 7 08-22-2010 09:34 PM
New Door with Wood Threshold Over Limestone BigJimmy Building & Construction 1 02-08-2008 05:36 AM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 07:16 PM
