Leaking Pipe - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 04:19 PM   #1
Leaking Pipe
Hello all! As a new homeowner, this is my first post on the forum and I look forward to many more!
I have a leak in my basement coming from my spare bathroom that I need to get fixed ASAP because I need to move in in two weeks but my master bath is going to be remodeled.
I have no ideas if these photos will help, but if someone could let me know if this is a leak I can fix myself or if I need to call a plumber that would be great!
Thanks!!
Drake
drakeab is offline   Reply With Quote
Old 06-01-2013, 04:22 PM   #2
After looking at these pictures again, I think it would be tough for someone to advise me one way or another. If anyone can give me any tell tale signs that I need a plumber or if it is something I can do myself, that would be great!
Thanks!
Old 06-01-2013, 04:50 PM   #3
Old School
Willie T's Avatar
One of the best tools for tracing the path of water (the trail it follows) is a bit of toilet paper. It will soak up water in places you may not even see it.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
oh'mike (06-02-2013)
Old 06-02-2013, 08:03 AM   #4
Bill Kearney
Rewards Points: 1,174
Kinda looks like the elbow under the tub is leaking. Could be as simple as new putty around the drain through the tub. Could be the elbow itself. Or, worse, it could be the tub itself has rusted.
But it's going to be tough going getting into that tight space.
If you've got all the tools and the time then it's not any harder than most DIY plumbing jobs. But the hassle will be trying to figure it all out and do it in that little bit of space. You could start by trying to unscrew the drain from the tub (from topside) and see what shape it's in. Put a fresh gasket or plumbers putty around it and screw it back in again. See if that stops the leak.
Is there an access panel upstairs that leads to wet wall of the tub? Before you do anything with the drain you'd want to make sure the leak isn't coming from farther up and dripping down to the trap along the curve of the tub.
wkearney99 is offline   Reply With Quote
Old 06-02-2013, 08:51 AM   #5
PoleCat's Avatar
Rewards Points: 1,646
My money is on the where the brass tube screws into the elbow.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Tags
bathtub , leak , leak in basement , plumbing
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Water leaking from vent pipe die_of_ennui Plumbing 3 03-25-2010 09:11 AM
How to fix a leaking waste pipe Pleco31 Plumbing 5 03-16-2010 10:15 AM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 05:32 PM
Leaking Pipe STEPBK2 Plumbing 1 12-06-2004 01:57 PM
