Leaking Hydrant - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 08:35 AM   #1
fgiesing's Avatar
Leaking hydrant
Is there a way to fix a leaking yard hydrant
fgiesing is offline   Reply With Quote
Old 07-22-2012, 08:51 AM   #2
DIY staff
Rewards Points: 7,174
Of course there is--if you can find the right parts---
There is a long rod attached to the head that has a black rubber washer on the bottom--that sets onto a brass seat---
Hopefully the washer is just worn or dried out--if the seat is bad--it will cost more for a 3 foot long Allen wrench than buying a new hydrant--
Unscrew the head from the pipe---lift out the head and rod---replace washer---while it's out--replace the packing under the brass nut where the handle is attached---the packing is shot on that unit,too.--Mike---
Old 07-22-2012, 09:19 AM   #3
fgiesing's Avatar
Thanks I was hoping I could unscrew that rod like a regular stem
Old 07-22-2012, 09:29 AM   #4
fgiesing's Avatar
So I'm thinking it's just packing since its only leaking when it's on.
Old 07-22-2012, 09:33 AM   #5
DIY staff
If that's the case---go buy a roll of packing---loosen the brass cap nut --remove old packing add some new and reset the cap nut---
No need to really take any thing apart---
Old 07-22-2012, 09:42 AM   #6
fgiesing's Avatar
Thanks again I'll try that
The Following User Says Thank You to fgiesing For This Useful Post:
oh'mike (07-22-2012)
shed frost hydrant leaking underground amakarevic Plumbing 15 03-08-2012 08:52 AM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 04:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
