Leak Finders? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-07-2008, 06:28 PM   #1
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Leak finders?
How or who do I call to do leak testing in my house? I'm looking for air and insulation leaks, and incidentally water leaks if air is leaking.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 08-07-2008, 07:32 PM   #2
Registered User
Termite's Avatar
Pre-purchase home inspection companies (the good ones) will have thermal imaging capabilites. They use a thermal camera to search for hot/cold spots in the walls, and they're incredibly effective. You simply walk around the room with the thermal camera aimed at the floor, walls, ceilings, and other features and you can see right into them based on their heat signature.
Old 08-07-2008, 07:49 PM   #3
Rewards Points: 2,906
There is also a way to find drafts on your own.
Just take a cotton shoe lace, cut the plastic tip off and light it. Once it's burning under it's own steam, blow out the flame so that the shoelace smolders, releasing a steady stream of smoke as it does.
Use that as a poor man's smoke pencil to check for air leaking in or out around electrical boxes, baseboards, window frames, door frames, etc.
Nestor_Kelebay is offline   Reply With Quote
Old 08-07-2008, 09:53 PM   #4
I'd think you have to first pressurize the house with a strong fan. . .?
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 09:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 02:18 PM
Leak on gas heater water line? darsunt Plumbing 3 04-16-2008 04:57 PM
