Leak In Drainage Pipe - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-27-2013, 05:32 PM   #1
leak in drainage pipe
I have been noticing an earthy smell in the dining room and bedroom above dining room for as long as I can remember. So I started digging today and discovered a partially disconnected elbow in the drainage system.
Is this enough evidence to support a smell in the 2nd floor bedroom?
Pipe leak
Pipe left and dining room window
Same as above but with upstairs bedroom window shown
brianxmurray is offline   Reply With Quote
Old 09-27-2013, 05:56 PM   #2
Are the fittings supposed to be glued or loose fitted?
Old 09-27-2013, 06:10 PM   #3
Rewards Points: 13,270
I guess you mean the down spout adaptors.
I never glue them.
Sometimes they need to be removed to rod out the drain lines.
It's not causing your "earthy" smell on the second floor.
Old 09-27-2013, 07:01 PM   #4
Just curious on why not glued... Attached is a picture of the driveway and the area above where the underground pipe is located appears to be sinking.
HELP!! I need advise on sewage pipe leak! aliciadw General DIY Discussions 7 05-21-2013 02:56 PM
Leak at toilet feed pipe dunixi Plumbing 5 01-28-2012 07:08 PM
Drain Pipe Leak AGF Plumbing 5 02-25-2011 08:58 PM
roof leak caused by furnace pipe. suzyp Roofing/Siding 1 02-06-2011 12:02 AM
How does this pipe work, and how do I stop the leak? jamolei Plumbing 10 12-20-2009 07:45 PM
