Lawnmower Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-20-2009, 12:52 PM   #1
Lawnmower problem
I have a Yard model riding mower. It was running great. Then it died after cutting half my yard. I tried to restart and it made a backfire noise. I tried again with the same result. It would only make a cranking noise afterward. It has a half tank of gas. I put a new spark plug in it but it would not start.
Can you help?
Joe Presnell
Joe Presnell is offline   Reply With Quote
Old 04-20-2009, 01:35 PM   #2
BIGRED
Rewards Points: 252
You, my friend, have what is known as a can of worms. Hold a long shank screwdriver to the cylinderhead and within 1/8" of the sparkplug. Turn the engine over, with the key or spin the flywheel. Do you get a spark??? You may have to do this 2 or 3 times if you are not in a dimmly lit area. If the Ignition is on you should get a spark of sufficient amplitude to light your fire. If not, eliminate the safeties. Disconnect the magneto kill wire and try again. It's on the side of the engine usually by the governor arm. The engine may start so be carefull. If not reconnect the wire. If this was the first run of the season take the float bowl off the bottom of the carb, but be carefull not to tear the little gasket if it sticks. You may have water, gum, dirt, etc. in the bowl. dump it out and wipe it out with a cloth. Get a spray can of carb cleaner and spray where the bowl was on the carb. Then pull the fuel line off the carb and spray carb cleaner into the fitting to the carb and wait. Do it again until you see it dripping from the carb where the bowl was. Put the bowl back on and spray carbcleaner down the throat (where the air goes) of the carb. Try to start the engine like a cold start, not a warm start. It may only run on choke at first. If so spray short bursts down the throat until it starts to smooth out. Go mow the lawn if it is running, but only at 3/4-full throttle until it is all done and spray for 8 seconds into the gas tank also. If none of this has worked you could have a lot of carbon buildup in the cylinder, or burned valves, a blown head gasket, or if you forgot the oil a siezed engine.
Grampa Bud is offline   Reply With Quote
Old 04-20-2009, 03:59 PM   #3
Rewards Points: 6,652
Did you check to make sure that the fuel feed is turned on to allow fuel to get from the tank to the Carb? Also, check the Carb to make sure the float is not stuck.
Old 04-20-2009, 05:27 PM   #4
When my Toro did that, I cleaned the air filter. It really needed it. Ran fine afterward. No air for combustion and the cylinder just fills with unburned gasoline. Easiest thing to try first.
Mike in Arkansas is offline   Reply With Quote
Old 04-21-2009, 10:44 AM   #5
Lawnmower problem
Thank you for responding to my problem!
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 05:57 PM
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 04:57 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
