Lawn Mower Not Starting - Any Ideas? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-16-2009, 11:18 AM   #1
Lawn Mower Not Starting - Any ideas?
Hi,
I have a Sears Craftsman B&S lawn mower. 6.5 HP and model # 917.388740.
Recently the air filter was clogged and I had a huge loss of power. In the process I took apart the primer, carb. And air filter housing area to clean it all up and change the oil. After putting it back together a problem I’ve noticed that it does not want to start.
The mower will only start when I tilt it all the way down on its left side for a few seconds (as if the blade is at a 90 degree angle) then yank the cord – this is the only way it starts. Once it starts it runs fine.
I still have to change the spark plug and put in a new filter (there is not filter in it right now), but one thing I’ve noticed is when I hit the primer all it does is pump air but no gas. I’m suspecting this is the problem but I’m not sure how this happened.
Any ideas? I’ve checked my work a few times now but I’m not able to find what went wrong when assembling everything back together.
Thanks!
topgun129 is offline   Reply With Quote
Old 07-16-2009, 06:52 PM   #2
Rewards Points: 344
Look on the bottom of the carb to see if there is a nut/screw. Remove this ( some gas will spill). There is a small pinhole in this screw. If it's clogged you can use a fine wire to clean it.
tribe_fan is offline   Reply With Quote
fix my Lawn Mower Starter myself !!! KUIPORNG Landscaping & Lawn Care 10 06-28-2009 01:34 PM
lawn mower problems jamesw6777 Tools 9 08-04-2008 01:22 PM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 12:25 PM
Rotary Lawn Mower jarg Landscaping & Lawn Care 9 07-03-2005 02:37 PM
