Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-29-2011, 10:08 PM   #1
Laundry tub question
Hi,
I'm trying to remove the cap like objects in the back corners of the laundry tub so that i can put my washing machine waste hose down there so i can hook it up to the drain pipe but for the life of me i can't get them out. I've looked from underneath and it doesn't look like you can screw them undone and they do have a rubber o ring on them...does anyone have any ideas?
anansa is offline   Reply With Quote
Old 03-29-2011, 10:14 PM   #2
Persona Non Grata
VIPlumber's Avatar
Try it with a pair of pliers. Should do the trick.
VIPlumber is offline   Reply With Quote
Old 03-29-2011, 10:40 PM   #3
i've tried it with everything it just isn't budging, i can get it a little way out and it looks as if it has an indent on the side to perhaps use a screw driver to leaver it out but after a certain point pulling it up it gets stuck
Old 03-29-2011, 10:48 PM   #4
Old 03-30-2011, 01:29 PM   #5
dremel tool with a cut-off wheel. One of the best tools I have.
speedtree is offline   Reply With Quote
Angled Laundry Chute Fox Remodeling 10 06-01-2010 12:09 PM
Basement laundry room secutanudu Electrical 9 04-23-2010 04:23 PM
Laundry Room Dimension Question jonathan03 Appliances 1 01-17-2009 11:08 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
