Laundry Detergent Dispenser - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-18-2010, 11:17 AM   #1
Rewards Points: 876
Hi;
I would like to build a simple dispenser for liquid laundry detergent.
I'm thinking of a plastic "bottle", at least 2 gallons with a relatively large opening on top to pour the detergent from the original container, and a hose or NPT fitting on the bottom for dispensing the liquid.
On the bottom I would attach a piece of pipe with a ball valve to control the flow.
I need the container to be of a translucent or transparent plastic so that I can see how much liquid it holds, but at the same time it needs to be sturdy enough to be attached to the wall and not break apart when full.
The reason I need this thing is that I am tired of the poorly designed large containers of detergent I have been purchasing at BJ's or Costco. In addition, these large bottles are difficult for older people to handle.
Thanks for your help
FW
Ultrarunner2017 is offline   Reply With Quote
Old 08-18-2010, 11:37 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Why reinvent the wheel? Couldn't you just mount a shelf to hold on of the dispensing bottles that the detergent comes in already, and stick a piece of clear poly tubing over the nozzle as an extension? then when you want detergent you push the lilltle ball on the OEM nozzle with one hand, and guide the tubing where you need it with the other.
If a person (old or young) has to pour 1 or 2 gallons from 1 container to another, i would think your idea would make the process more dificult, not less
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-20-2010, 10:48 AM   #3
Rewards Points: 876
Actually, it was the failure of the little OEM ball that caused me to want another method. It only happened the once, but it caused loss of some of the product. Luckily it happened while someone was trying to use it, not all by itself when no one was around.
I guess you're right about this though. Why go to all the trouble when there's already a dispensing method built-in. I just wish that they made these things with a little more quality. Maybe if I could buy another nozzle to screw onto the bottles when I buy them. If the thread matches anything "normal" I could make one myself.
FW
Remodeling laundry closet bplaird Carpentry 11 05-09-2011 05:44 PM
Angled Laundry Chute Fox Remodeling 10 06-01-2010 11:09 AM
Basement laundry room secutanudu Electrical 9 04-23-2010 03:23 PM
Upstairs Laundry Room Install Matt Burks Remodeling 3 08-21-2007 11:12 PM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 10:35 AM
