Lath And Plaster - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 06:26 AM   #1
fbull66's Avatar
Lath and plaster
How do I anchor anything to lath and plaster...( hand rail... Tv mont..)
fbull66 is offline   Reply With Quote
Old 07-26-2012, 06:34 AM   #2
DIY staff
Rewards Points: 7,174
Handrails and T.V.s need to be mounted right to a stud,just like drywall---
Lighter items can be anchored using Molly bolts---Mike---
P.S.--Moved this to general--
Old 07-26-2012, 06:35 AM   #3
the Musigician
DangerMouse's Avatar
Molly/toggle bolts perhaps? Not that I'd trust them to hold too much weight. Use a stud finder and mount to those.
DM
Old 07-26-2012, 06:36 AM   #4
fbull66's Avatar
Im havering a hard time finding the 2x4. ..with a stud finder...
Old 07-26-2012, 06:37 AM   #5
the Musigician
Day late and a dollar short.... story of my life.
DM
Old 07-26-2012, 06:43 AM   #6
DIY staff
Some stud finders are better than others---
Try this---the base molding is nailed to the studs--attach a rare earth magnet to a string--swing it along the base board until it sticks--there is your stud---My phone case has one of those magnets--
Old 07-26-2012, 06:51 AM   #7
the Musigician
...orrrr..... just open an old hard drive, yank the rare earth magnet from that and just move it around the walls until it finds the nails/screws used to attach the lath to the studs. Then measure between them. They SHOULD be 16" OC. Or just use the magnets and be sure of what's underneath.
Good call Mike.... I keep forgetting about those magnets, even though it's how I found my own studs!
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
oh'mike (07-26-2012)
Old 07-26-2012, 06:54 AM   #8
DIY staff
Lath is nailed to the studs---Listen to Danger---go low tech---use a magnet---
Dierte (07-26-2012)
Old 07-26-2012, 07:36 AM   #9
fbull66's Avatar
Great idea thanks ...wow it's a pain ..thanks guys
Old 07-26-2012, 09:29 AM   #10
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
I was painting the kitchen wall I was hanging shelves on so before I painted I used this ancient technique called "drill a 1/8" hole every inch and stick a coathanger through it"
This technique should only be used when the wall in question is being painted though HA!
CoconutPete is offline   Reply With Quote
Old 07-26-2012, 05:21 PM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
correction SHOULD be
chrisn is online now   Reply With Quote
Old 07-26-2012, 05:23 PM   #12
chrisn's Avatar
Rewards Points: 312
DM
now thats more like it, my house is not
Old 07-26-2012, 05:27 PM   #13
DIY staff
I'm not too politically correct---but my answers USUALLY are.
Old 07-26-2012, 05:32 PM   #14
the Musigician
999 out of every 1,000 seems pretty good to me Mike.
DM
Old 07-27-2012, 04:47 AM   #15
chrisn's Avatar
Rewards Points: 312
Just trying to let the DIY's now, things are not sometimes what the seem
Old plaster lath ceiling 1910rowhouse Drywall & Plaster 3 03-29-2012 11:32 PM
Question about lath and plaster walls mandieshawn Building & Construction 9 05-18-2011 08:43 PM
Opening up lath and plaster, need to tear it all down? brandnew Drywall & Plaster 3 09-09-2010 09:51 PM
mounting things on lath and plaster walls wilderstyle General DIY Discussions 11 01-17-2010 08:48 AM
Installing baseboards on lath & plaster B Scott Remodeling 6 07-05-2008 09:29 PM
