Large Safe Purchase... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-02-2007, 10:39 PM   #1
kemerick's Avatar
Rewards Points: 87
large safe purchase...
I know this may not be the place but I am just wondering if anyone has bought a Cannon Safe before? If so, are you happy with it?
Costco has one that looks pretty nice and browsing around the web it looks to be a pretty good deal. Costco usually carries pretty good quality stuff and I am in the market for a big safe to store all kinds of stuff in. Here is the one I am looking at:
http://www.costco.com/Browse/Product...lang=en-US&s=1
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 11-03-2007, 08:18 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I don't have one. But, here is the same safe on Cabela's Website (at $899.00) with 5 reviews of it showing a customer rating of = 5 stars.
Link: http://www.cabelas.com/cabelas/en/te...Safe&noImage=0
- Build Well -
Old 11-03-2007, 09:49 AM   #3
Eibwen
Cannon is a good brand name
The UL rating only applies to the Sargent and Greenleaf lock made in good ol KY USA.
Make sure you bolt the safe down only thru the holes provided since its only 450 pounds.. UL says bolt down on anything under 750.
Get the dehumidifier or poly bag anything that will rust. Fireproofing emits moisture... Open the safe once a week for awhile to let it dry out.
This safe will not protect computer media in a fire since it needs a much higher protection rating.
Sammy is offline   Reply With Quote
Old 11-03-2007, 11:40 AM   #4
kemerick's Avatar
Rewards Points: 87
Right on, I will get it... and bolt it down to the slab.
Old 11-03-2007, 12:18 PM   #5
Eibwen
Fixed sleeve anchors work best for your bolt down versus lags and bolts if your bolting to concrete. 1/2" or 5/8"
Good luck!
Old 11-03-2007, 10:20 PM   #6
kemerick's Avatar
Rewards Points: 87
By fixed sleeve, you mean like the RedHead anchors you pound into the hole and use a bolt to screw into it? I used them for my JD Squared tube bender and they work great:
http://www.itw-redhead.com/multi_prod01.asp
Old 11-04-2007, 08:51 AM   #7
Eibwen
I like the fixed sleeve anchors [I think they call them dynabolts in Red Head] since they are all one peice versus a drop in anchor and seperate bolt. It allows you to do it all thru the hole in one application without having to move a 450 pound safe.
My safe bolt down guys used to use the drop in anchors but prefer the fixed sleeves for ease of use.
Freestanding/portable safe home heaters?? sugarmama HVAC 5 10-30-2007 08:23 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 05:28 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 04:50 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 08:16 AM
