Laminate Staircase - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-04-2008, 07:12 PM   #1
Question
Laminate Staircase
Hi all....great site,
I'm about to take on the project of laminate flooring my staircase. I'm just a little unsure on the best way to do this. Should I brad nail the stairs in....should I use a construction adhesive? Do I need to use underlay on stairways (stands to reason that "no" due to the fact laminate is slippery enough) What is the best "low trip hazzard" to join the riser and tread?
Any advice at all is appreciated. Thanks
Ed
Eddie Funk is offline   Reply With Quote
Old 08-05-2008, 09:00 PM   #2
Rewards Points: 5,332
You would follow the detailed instructions of the manufacturer.
Ron
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 01:18 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Best quality underpad to use for laminate?? sillysimms Flooring 4 07-27-2011 05:05 PM
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 07:07 AM
Suggestions Needed - Laminate on Staircase Bob_Zahn Flooring 6 05-13-2008 10:11 PM
