Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-19-2006, 09:42 AM   #1
Laminate floor covering on stairs?
I am considering the left over laminate flooring I have to cover the inside stairs to replace the worn out carpeting I currently have. I have seen this done and it comes out very nice and neat.
One concern I have is the potential for a slippery surface. This will be the main stairway leading form the outside into the home and up to the living room area. Should I be worried that the surface may be slippery? I realize other homes use hard woods stairs all the time. Just want to ease the concerns a little.
Thanks in advance for your help.
DK75 is offline   Reply With Quote
Old 10-19-2006, 12:06 PM   #2
General Contractor
I personally tell my customers that it is a bad idea to install laminate on stairs. Because it is so slippery. I will not install them on stairs for that reason. I would rather lose the business than worry if someone would get hurt. Just my opinion.
Hammatime is offline   Reply With Quote
Old 10-19-2006, 09:16 PM   #3
remodeling pro
I think the slipperyness is a real issue also. I would not recommend it. Just curious, what were your plans for the exposed edges at the tread noses?
troubleseeker is offline   Reply With Quote
Old 10-20-2006, 08:40 AM   #4
I have plenty of left-over laminate flooring from the previous owner I planned on cutting to length for each stair tread and riser. I have found a couple different style stair nosing strips that are designed to fit over the tread for a nice rounded finish. The two I have found either fit over the laminate that is on the tread which leaves a slight differnence in height, or there is a nosing strip that fits with a tongue/groove style connection to the laminate leaving a flush mount.
My inspiration for this project was seeing my in-laws house do the same thing. They however have put laminate on only about 5-6 stairs that lead from the kitchen to the basement. It turned out really nice and easy to walk on. The difference I have is the stairs will be a walkway from the outside and peoples shoes can be wet from weather or snow.
Old 10-21-2006, 05:38 PM   #5
Super Moderator
Floorwizard's Avatar
I never tell a client what to do or not do in their home.
this is their home and they are entitled to do whatever they want.
I show them the features, benefits and advantages to all products they are interested in, and also the possible problems.
I do TONS of lam and wood steps. I tell them it will be a danger if they do not install a stair runner or have something else to help with grip. Such as small pieces of carpet bound and set on the steps.
Carpet wears out quickly, and looks goofy with a house full of lam, or wood. but again, it's THEIR home.
Time to ride again!
Floorwizard is offline   Reply With Quote
Old 11-08-2006, 01:40 PM   #6
I understand the concern of having a potentially slippery flooring on the stairs, however, I live in a townhome that has the entry on the first floor and the living space on the second. That being said, the front door leads directly to the carpeted stairs that are being destroyed by daughter, dog and myself. The stairs have a rounded bullnose. How can I install laminate??? P.S. I live in florida, the front porch is covered and there is a tiled landing at the bottom of the stairs. I am not to concerned about moisture.
natzNsarh is offline   Reply With Quote
Old 11-08-2006, 01:41 PM   #7
I just noticed this thread is from '03. If I am talking to myself, I am really not crazy, just non-observant....
Old 01-12-2007, 01:28 PM   #8
gt1
Hello everyone!
I am planning for a laminate on stairs. The brans I use has attached underlayment. Should I rip it off before the installation, or leave it there and glue the anderlayment to the boards on the stair?
gt1 is offline   Reply With Quote
Old 09-06-2007, 02:38 PM   #9
Manufactuer told me that DO NOT RIP THEM OFF, leave them and glue.
liguowei70 is offline   Reply With Quote
Old 09-06-2007, 08:14 PM   #10
gt1
Thanks for the reply. I already finished the stairs, gluing planks with underlayment. Turned out really good.
More On This Topic
Use a quarter cup of Windex to a gallon of water when cleaning laminate flooring, and apply it through a spray bottle. Avoid using Pledge when cleaning laminate flooring with advice from the owner of a cleaning service company in this free video on... Read More »
Snap laminate flooring is held together by a tab and a groove that lock together to form a tight seam. Find out how to install a foam moisture barrier when adding snap flooring with help from a home repair specialist in this free video on home... Read More »
Use vinegar and water or a commercial pine cleaning solution to mop laminate flooring. Clean laminate floors with the housekeeping tips in this free video on home maintenance from a professional decorator and home cleaner. Read More »
Mix a pine cleaner with water to create a solution for mopping laminate flooring, then mop with a back-and-forth motion. Clean laminate flooring with the housekeeping tips in this free video on home maintenance from a professional decorator and home... Read More »
Laminate floors are not too sensitive, but vinegar and water makes for a much better, homemade alternative to cleaning than harsh chemicals. Use a splash of vinegar in a bucket of water to clean laminate floors with help from a professional house cleaner... Read More »
laminate install diyjoe Flooring 15 11-23-2007 03:49 AM
HELP - laminate on stairs mf915 Flooring 6 07-11-2007 11:12 PM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 09:43 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
Laminate Flooring - Newbie Trishl Flooring 9 04-22-2006 12:20 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
