Laminate Floor, Basements And Asbestos Tile - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-22-2009, 11:08 PM   #1
laminate floor, basements and asbestos tile
Hi all, I know there have been many threads on laminat floor in the basemnet. I hear about 6mil, vapor barrier, sealer and cushion under the laminate if the floor is concrete.
My question is the I have asbestos tiles in my basement and have no desire to take it up. I want to put laminate flooring in the basement so i have these questions:
1) do i need a 6 mil vapor barrier over the asbestos tiles?
2) I am assuming I don't need a sealer since it's not over concrete. However, there are some areas where the tiles have come up, how would i address those areas, or do i need to?
3) Are there any advantages/disadvantages buying laminate floor with preinstall cushion, or should i buy them separately? OR does not really matter?
4) Do I need to glue them in the basement?
Thanks, after much internal debate, I think laminate floor is the way I will go, but if someone can convince me otherwise, i would reconsider. I did look at the armstrong cushion step, but it cost too much, and i wouldn't know how to install it myself. Ceramic tiles are no good, cuz I would need to take up the absestos tiles
THANKS
geandham is offline   Reply With Quote
Old 09-23-2009, 08:45 AM   #2
Rewards Points: 5,336
The install sequence would be to follow the manufacturers instructions. Many laminate floors are not recommended for below grade.
The padding on the back I find to be very convienient.
Ron
Asbestos tile and mastic phillyDIYER Flooring 14 08-21-2011 02:46 PM
Encapsulating old asbestos vinyl tile Familypro40 Flooring 17 03-22-2009 04:20 PM
Assuming Asbestos Tile mcconnre Flooring 35 11-14-2008 02:56 PM
Asbestos tile? nugentcn Flooring 23 08-31-2008 11:42 PM
Tile over very old laminate secured to concrete? B Parker Flooring 13 03-30-2008 03:15 PM
