Lag Screw Newb Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-28-2015, 12:59 PM   #1
Rewards Points: 2
lag screw newb question
I apologize in advance for this newb question. Remounting a TV on the wall but threw out the instructions. The screw size is 1/2" head, but says 8.8 on it. I just need to know what size pilot hole to drill.
Thanks in advance!
amnesiajack is offline   Reply With Quote
Old 01-28-2015, 02:15 PM   #2
Rewards Points: 1,668
The 8.8 may be the metric diameter of the screw ( major diameter ). The pilot hole should be approximately the root diameter of the screw (minor diameter ). In a scrap piece of lumber try boring a 9/32" hole and see if it be something you could approve of. If that seems too loose try a 1/4".
SeniorSitizen is offline   Reply With Quote
Old 01-28-2015, 02:17 PM   #3
Special User
Rewards Points: 1,230
8.8 is a metric designation and I can't find any charts that show head size vs. pilot drill size. I would pick a drill bit slightly smaller in diameter than the root of the lag threads.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 01-28-2015, 02:34 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,614
Thanks in advance!
Ayuh,.... A 1/2" head on a metric bolt is a 13mm head, the 8.8 is the grade of metal,....
A 13mm head on a lag bolt would have 8mm threads, so a 3/16" drill for wood,...
Bondo is online now   Reply With Quote
The Following 2 Users Say Thank You to Bondo For This Useful Post:
mae-ling (01-28-2015), tylernt (01-28-2015)
Question regarding bonding screw. dabeast Electrical 14 10-09-2013 09:26 AM
Newb Question new2thecrew Plumbing 12 04-16-2013 01:06 AM
How to repair a ABS soil stack with a drywall screw in it? ThatGuy Plumbing 10 02-22-2012 10:36 AM
I think I put a lag screw into a vent pipe. noone Plumbing 60 01-09-2012 11:13 PM
Question about removing a screw type fuse box... OmegaBunny Electrical 9 09-15-2008 10:13 PM
