Ladder Parts - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 01:58 PM   #1
jad
Ladder parts
I have a 28 foot aluminum extension ladder but but both the locks are broken.... not really broken they just seem to be missing some type of spring that allows them to bounce along the steps till you want it to lock onto a step. The locks are fine and lock onto to the step they just do bouncd along..... if you know what I mean?
It is about 10 yrs old but the manufactures label is worn off so I do not know who makes it to look for parts?
It say model # 36028 and also says made in USA.
I check the Werner and Louisville web site but nothing close to that model number? Anyone know I may find what I need?
thanks
jad is offline   Reply With Quote
Old 06-04-2011, 05:44 PM   #2
Rewards Points: 5,336
Most manufacturers should be able to be used as long as the steps are a near size and shape.
Ron
Old 06-04-2011, 09:29 PM   #3
Too Short? Cut it Again!
Not sure I remember ever having an extension ladder with spring loaded rung locks? I am old though.
Whatever you do? If you don't trust your ladder, get rid of it and fork out for a new one.
Expensive suggestion? In what context? Using something unsafe and ending up falling off from 30 feet in the air with possible consequences I will not go into. Look on Craig's List or eBay for your area. There are some great deals out there in this sad economy.
Old 06-05-2011, 08:52 AM   #4
Rewards Points: 2,238
I've got 5 Werner, aluminum extension ladders (22' to 40').
They all have springs on the rung locks.
Do a search on "Industrial Scaffold and Ladders".
It's safe to use them without the springs - well, sort of!
I've done it but, I wouldn't advise anyone else to!
OK - DON'T do it!
rossfingal
rossfingal is offline   Reply With Quote
Old 06-05-2011, 12:16 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 54
Just watch the weight rating, many of those cheap aluminum ladders are for small people.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
rossfingal (06-06-2011)
Old 06-05-2011, 12:29 PM   #6
kwikfishron's Avatar
Rewards Points: 196
You really need the correct replacement part.
Modifying your ladder or the wrong part to fit isn’t a good idea.
If you do a search you’ll see there are no generic replacement kits, there’s a reason for this.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
How to assemble a PVC drain unit without gluing all parts together? sukhenkoi Kitchen & Bath Remodeling 3 03-28-2011 10:00 AM
Ladder lift JasonJr Carpentry 14 03-04-2011 07:56 AM
Are "Genuine OEM" replacement parts necessary for a furnace? hvacdiy HVAC 3 11-19-2010 10:09 AM
installing a ceiling ladder jerry1967 Carpentry 6 11-21-2006 12:18 AM
