Kwikset Deadbolt Removal Issues - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-10-2017, 10:37 PM   #1
Hello there,
I have a kwikset deadbolt set on my front door in my new house. I purchased a smartlock that attaches to my deadbolt turner, however I've have had some issues in the process. I need to access the screws to unscrew the deadbolt, however they are behind a faceplate/cover with the deadbolt turner on top of it. I can pop the faceplate back a little bit, however I cannot remove it without removing the deadbolt turner. There is a little hole on the side of the deadbolt turner for a hex Allen wrench that requires a 1/16th wrench size (confirmed via email by kwikset). I have tried sizes close to that yet didn't get an actual 1/16th until tonight.
The problem now is that either the hole seems stripped, or it doesn't seem to have something that would actually unscrew. I just want to remove the deadbolt turner and access the screws on my front door deadbolt! I have received the idea to try an EZ out and will try that out. Do you guys have any other ideas?!
Kwikset Deadbolt Removal Issues-img_0578_1484105785022.jpg   Kwikset Deadbolt Removal Issues-img_0452_1484105800749.jpg   Kwikset Deadbolt Removal Issues-img_0451_1484105818622.jpg
Dakota747 is offline   Reply With Quote
Old 01-10-2017, 11:10 PM   #2
Rewards Points: 680
Re: Kwikset Deadbolt Removal Issues
That set-screw looks to have been SMURFED by someone that did not know what they were doing.
If you cannot get the correct hex tool to work, you will need to drill it out and replace it.
Maybe you can just replace the lever, but getting one might be a task.
Be gentle with it, it is only a brass fitting.
ED
de-nagorg is online now   Reply With Quote
Old 01-10-2017, 11:16 PM   #3
Thank you for the response! What would be the process of drilling it out?
Old 01-10-2017, 11:29 PM   #4
Rewards Points: 680
Getting room for a drill in there might be hard, but worth a try.
You need a bit the same size as the hole the screw is in, then a drill small enough to go straight into the screw hole, I suggest a 1/4 inch electric drill (corded), as a start, or maybe a Right Angle attachment on a drill.
Maybe a Dremel might be small enough to drill it.
Go slow and straight, until the set screw is removed, then the lever should easily pull off.
Since the set screw is mangled, you might need to hire a locksmith to do this work, because you can't, and they have many specialized tools to work on these.
ED
Old 01-11-2017, 12:47 AM   #5
jlhaslip's Avatar
Rewards Points: 354
Might try a screw extractor on the damaged hex shape before the drill out attempt.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 01-11-2017, 02:26 PM   #6
Rewards Points: 402
why not drill it out, replace the entire deadbolt mechanism?
KPDMinc is offline   Reply With Quote
Cold walls, humidity issues, frost issues with exterior doors Howitzer Insulation 46 12-14-2014 10:56 AM
New Roof Install - Problems and issues. cjaustin81 Roofing/Siding 110 09-13-2014 09:44 PM
Steel Entry Door Issues framinghammer Carpentry 6 06-25-2009 06:50 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
