Kitchen Drawer Rail Fix - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 10:09 PM   #1
Hi DIY,
I put too much in a kitchen drawer and the plastic part that holds the rail broke. Please tell me the name of the part I need to get and how to go about attaching it (looks like a simple staple gun job, no?).
whatupdun is offline   Reply With Quote
Old 02-26-2012, 10:12 PM   #2
Old School
Willie T's Avatar
That may be a tough item to find because it was probably made to fit only that specific glide.
Willie T
Old 02-26-2012, 10:14 PM   #3
Thanks for the quick reply.
Should I just get a new glide?
Old 02-26-2012, 10:17 PM   #4
Old School
Willie T's Avatar
HERE'S A POSSIBILITY. http://www.rvpartsnow.com/kwikee-6-t...mper-906466002
Or just Google Drawer Glide Holders or Drawer Glide Sockets.
Local RV suppliers might carry them, as things like that are ALWAYS breaking on RV's.
Willie T
Old 02-26-2012, 10:23 PM   #5
Thanks again, those look like what I broke. Now the only challenge will be finding one that fits among the millions available
Old 02-26-2012, 10:52 PM   #6
Rewards Points: 13,456
A mobile home supply may also have them.
They use super cheap drawer guides like that.
Old 02-26-2012, 11:00 PM   #7
Look real close and see if you can see any info on the guides. A brand name would be a huge help.
Lowes and Home Depot both carry a few differant brand of guides. Bring both piece with you when you go to match them up.
Old 02-27-2012, 09:02 AM   #8
Just bolt an "L" bracket to th rail the to the back
antlerdancer is offline   Reply With Quote
Old 02-27-2012, 09:24 AM   #9
MarginallyQualified
Rewards Points: 2,464
It's called a "socket" and any (ANY!) decent hardware will have one close to yours.
Old 02-27-2012, 04:34 PM   #10
If you look on the bracket you already have for the rail there are screw holes at the top and the bottom. You could just get yourself some epoxy and a small screw.
Mix your epoxy, put it on the piece that has broken off and between it and the piece still attached. Screw them both on with a small (1/4") screw. Those brackets were not made to be stapled on - that's why they have screw holes and no "staple" holes....
Handierman1 is offline   Reply With Quote
Old 02-27-2012, 05:02 PM   #11
Household Handyman
Rewards Points: 1,408
Local HomeDepot has a "generic" socket to fix this, they should have the metal type like I have bought. It will have a socket for the rail to fit into, instead of being specific for this type rail. This will give you a little wobble when assembled and a little noise. I stopped the noise by putting a bit of silicone in the socket to dampen the vibration. The staples are for fast assembly, not quality assembly for sure. On the new one use small wood screws, they will last longer.
Old 02-27-2012, 05:08 PM   #12
jschaben
Rewards Points: 502
I doubt if that plastic will glue worth nuts. Getting the right configuration may be a trick but that type of slide sells for about $5/pair although matching sockets will be extra. Try Home Depot, if they haven't got a matching socket, just pick up a new set of slides with sockets to match.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 12:42 PM
Need to find very low profile kitchen drawer hardware galmoughraby Interior Decorating 1 01-10-2011 12:58 PM
Kitchen drawer joint part chulheekim General DIY Discussions 9 12-10-2010 11:15 PM
kitchen organization mferguson0414 Carpentry 4 01-11-2009 11:51 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
