Kitchen Drawer Organizer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 11:34 AM   #1
kitchen drawer organizer
Hello
This is my 1st post on the forum. We have deep kitchen drawers that are set up for vertical storage of pots, lids,trays, etc. Glass partitions separate the various contents. The partitions are slotted into plastic groves in the front & back of the drawers. I believe the plastic material was originally in rolls with adhesive backing. Over time these have deteriorated. I have looked everywhere but cannot find replacements. I would appreciate any help you can offer or for alternative ideas. I've attached a photo to show the material.
joelkoro is offline   Reply With Quote
Old 06-19-2012, 12:02 PM   #2
Too Short? Cut it Again!
Don't see your photo?
Old 06-19-2012, 12:46 PM   #3
I did attach the photo and it was on the message when I reviewed it but failed to end up on the final post.
Here is the URL again:
http://www.flickr.com/photos/80720802@N05/7402180520/
Old 06-19-2012, 01:50 PM   #4
It does look like some sort of vacuum formed plastic tape. I wonder if dado cuts in some other material like wood would hold up better. Only problem would be I am guessing your glass shelves are cut fairly snug? The would have to be trimmed to accommodate the base of the wood.
I will see what I can find for you. My curiosity is aroused.
Old 06-19-2012, 04:06 PM   #5
Thanks for your interest and help. I have thought about routing some thin wood, but have procrastinated and have continued to hope to find the original. If it helps, the original material was applied about 15 years ago with a kitchen remodel.
Joel
Old 06-20-2012, 12:30 PM   #6
Bombed out having tried every search string I could think. Router or dado blade may be your best bet? Resulting base thickness vs shelf length will be your challenge. I guess you just need it long enough to place the strip with Gorilla glue or something. Could then chisle voids away?
The Following User Says Thank You to user1007 For This Useful Post:
joelkoro (06-20-2012)
Old 06-20-2012, 12:41 PM   #7
Many thanks for your help.
Joel
Old 06-21-2012, 10:36 AM   #8
jschaben
Rewards Points: 502
Might be able to duplicate that strip(s) in HDPE (plastic cutting board material). The problems there would be fastening it in place, HDPE is a little tricky to glue. I'd probably machine in a couple of bosses to accept screws from the outside of the draw box. Another issue may be that the, I assume tempered, glass dividers may need to be cut a tad shorter depending on how thin you end up with on the ends.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-21-2012, 11:00 AM   #9
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Sounds familiar but I believe it was originally made for CD storage. Have you searched for it that way?
Edited to add: It's sorta hard to see, but it looks like the CD storage in this desk.
http://www.walmart.com/ip/Morgan-Com...tural/19793557
Old 06-21-2012, 05:47 PM   #10
kitchen drawerorganizer
HMMMMMM. Good idea. I'll check out what's available.
Old 06-21-2012, 06:36 PM   #11
I bought some U shaped, brass channel strips at Home Depot for a similar application. It came with screw holes for mounting purposes. Perhaps you could use something like this.
Old 06-21-2012, 07:08 PM   #12
Hi,
Could you give me a better description of these? Which department were they in?
Joel
Old 06-21-2012, 10:09 PM   #13
Hi,
Joel
I found these in the place where they keep cabinet hardware. They were internded to be used as tracks for horizontal, sliding doors.
The Following User Says Thank You to Wildie For This Useful Post:
joelkoro (06-22-2012)
Need photos of OPEN split FOYER landing in kitchen suegee1950 Remodeling 3 03-11-2013 09:24 AM
Kitchen relocation, are HVAC registers needed bion HVAC 5 04-11-2012 07:47 PM
Need to find very low profile kitchen drawer hardware galmoughraby Interior Decorating 1 01-10-2011 12:58 PM
Kitchen drawer joint part chulheekim General DIY Discussions 9 12-10-2010 11:15 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
