Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-11-2013, 03:41 PM   #1
kitchen cabinet doors won't shut
I have the original builder's kitchen oak cabinets from 1990.
The hinges are exposed but I do not know why they won't close, most of them are open a bit.
Can the hinge be adjusted or must one resort to use velcro or other things?
DIYGST is offline   Reply With Quote
Old 01-11-2013, 03:45 PM   #2
Without a picture how would we even know what hindge you have?
Old 01-11-2013, 04:36 PM   #3
STAFF
BigJim's Avatar
Most times you can spring the hing and make it work better. If you can post a picture it may help.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 01-11-2013, 04:55 PM   #4
Nest Home Improvement
NestHI's Avatar
It depends on the actual hinge. A picture would help!
NestHI is offline   Reply With Quote
Old 01-11-2013, 05:04 PM   #5
Super Moderator
Many of those hinges have a built in plastic spring---old age may have caused their death---
Remove a good hinge and see if it snaps closed---then your bad hinge---I think your hinged are shot---new hinges are available at a reasonable cost and are easy to change---let us know what you find---
Old 01-11-2013, 05:07 PM   #6
mine is very similar to this.. pic coming soon
http://www.doorcorner.com/ambpoilrub....IZaK8uQA.dpbs
Old 01-11-2013, 05:11 PM   #7
NestHI's Avatar
Couple of things it might be.
-Hinge could be bent.
-Could be loose and needs tightening
Old 01-11-2013, 10:04 PM   #8
STAFF
BigJim's Avatar
Have you painted the hinge?
Jim
Old 01-11-2013, 10:09 PM   #9
There is no adjusting that style, Remove one and take it with you to any box store, There's differant off sets and screw spacing.
Old 01-11-2013, 10:48 PM   #10
STAFF
BigJim's Avatar
Believe it or not there is.
Jim
Old 01-12-2013, 06:07 AM   #11
Super Moderator
Have you remove a couple yet ,to test the springs?
Old 01-12-2013, 07:59 AM   #12
NestHI's Avatar
Replace these hinges and your doors will stay closed.
Sanding Swinging Door and Cabinet Doors...NEWBIE jmiza Windows and Doors 8 12-31-2012 07:21 PM
Access through kitchen cabinet to pipes taylorroad Carpentry 4 09-01-2012 07:09 AM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 12:44 PM
Kitchen cabinet doors jad Kitchen & Bath Remodeling 2 04-13-2010 09:35 AM
Replacing just the kitchen cabinet doors? imola ghost Remodeling 7 02-24-2010 12:03 PM
