-   General Discussion (http://www.diychatroom.com/f2/)
-   -   kitchen cabinet doors won't shut (http://www.diychatroom.com/f2/kitchen-cabinet-doors-wont-shut-168851/)
DIYGST 01-11-2013 03:41 PM
I have the original builder's kitchen oak cabinets from 1990.
The hinges are exposed but I do not know why they won't close, most of them are open a bit.
Can the hinge be adjusted or must one resort to use velcro or other things?
joecaption 01-11-2013 03:45 PM
Without a picture how would we even know what hindge you have?
BigJim 01-11-2013 04:36 PM
Most times you can spring the hing and make it work better. If you can post a picture it may help.
NestHI 01-11-2013 04:55 PM
It depends on the actual hinge. A picture would help!
oh'mike 01-11-2013 05:04 PM
Many of those hinges have a built in plastic spring---old age may have caused their death---
Remove a good hinge and see if it snaps closed---then your bad hinge---I think your hinged are shot---new hinges are available at a reasonable cost and are easy to change---let us know what you find---
DIYGST 01-11-2013 05:07 PM
mine is very similar to this.. pic coming soon
http://www.doorcorner.com/ambpoilrub....IZaK8uQA.dpbs
NestHI 01-11-2013 05:11 PM
Couple of things it might be.
-Hinge could be bent.
-Could be loose and needs tightening
BigJim 01-11-2013 10:04 PM
Have you painted the hinge?
joecaption 01-11-2013 10:09 PM
There is no adjusting that style, Remove one and take it with you to any box store, There's differant off sets and screw spacing.
BigJim 01-11-2013 10:48 PM
Believe it or not there is.
oh'mike 01-12-2013 06:07 AM
Have you remove a couple yet ,to test the springs?
NestHI 01-12-2013 07:59 AM
Replace these hinges and your doors will stay closed.
