Kiln Drying Lumber With Wood Heat? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 04:20 PM   #1
Kiln Drying lumber with wood heat?
Does anyone have plans for a small wood fired kiln? I am just starting with a portable saw mill and want to find a way to dry my own lumber in a low cost way. Does anyone have any information? Thanks.
rdpierce is offline   Reply With Quote
Old 12-23-2012, 04:58 PM   #2
Rewards Points: 1,232
Time is cheap, shim it and cover it and leave it alone.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 12-23-2012, 05:31 PM   #3
Rewards Points: 960
I bought some lumber from a guy recently and it was advertised as kiln dried. I asked him what sort of set up he had. He explained that he heated his house with a woodburner which is outside the home. He simply fills up his basement with wood, fires up the woodburner, and monitors the humidity inside and the moisture of the wood.
I suspect that if you have a woodburner and a building, you could simply put the woodburner in the building with the wood and fire it up. You would have to allow some ventilation so the moisture can escape. I also would consider providing outside air to the firebox if the room is tight.
cleveman is offline   Reply With Quote
Old 12-23-2012, 07:11 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,.... I gotta agree,... Kilns dry wood with Steam, not just dry heat...
Forced air dryin', like yer talkin' 'bout causes alota splittin', 'n twistin' in the wood...
Old 12-23-2012, 08:54 PM   #5
Rewards Points: 960
When I have bought air-dried wood, it was dried for 2 years.
I think if you put 20,000 bf of wood up, and plan on selling it for $3/bf, most guys don't want to wait 2 years for that money to roll in. Hence the kilns.
There is also the possibility of a solar kiln. I think the deal here is you keep it in a dry, protected, well ventilated area, but with the south side glassed in.
The other disadvantage of air drying, which was explained to me, is the rot factor. Seems the softer woods such as basswood will get a bit moldy during the natural air drying process.
Old 12-27-2012, 09:42 AM   #6
Rewards Points: 626
Build a weather shed and sticker the lumber have good air flow and let it dry. You can look up the tables for air drying by the USFS.
Nailbags is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Heat exchanger for a wood stove rygar HVAC 2 11-14-2012 08:03 AM
Heat won't stop running, just installed new thermostat NorthSidePK HVAC 28 11-01-2012 10:05 AM
want to make an ultra cheap wood kiln - any advice? wombosi Carpentry 5 03-20-2010 04:39 PM
