-   -   Kiln Drying lumber with wood heat? (http://www.diychatroom.com/f2/kiln-drying-lumber-wood-heat-167216/)
rdpierce 12-23-2012 04:20 PM
Does anyone have plans for a small wood fired kiln? I am just starting with a portable saw mill and want to find a way to dry my own lumber in a low cost way. Does anyone have any information? Thanks.
Tscarborough 12-23-2012 04:58 PM
Time is cheap, shim it and cover it and leave it alone.
cleveman 12-23-2012 05:31 PM
I bought some lumber from a guy recently and it was advertised as kiln dried. I asked him what sort of set up he had. He explained that he heated his house with a woodburner which is outside the home. He simply fills up his basement with wood, fires up the woodburner, and monitors the humidity inside and the moisture of the wood.
I suspect that if you have a woodburner and a building, you could simply put the woodburner in the building with the wood and fire it up. You would have to allow some ventilation so the moisture can escape. I also would consider providing outside air to the firebox if the room is tight.
Bondo 12-23-2012 07:11 PM
Ayuh,.... I gotta agree,... Kilns dry wood with Steam, not just dry heat...
Forced air dryin', like yer talkin' 'bout causes alota splittin', 'n twistin' in the wood...
cleveman 12-23-2012 08:54 PM
When I have bought air-dried wood, it was dried for 2 years.
I think if you put 20,000 bf of wood up, and plan on selling it for $3/bf, most guys don't want to wait 2 years for that money to roll in. Hence the kilns.
There is also the possibility of a solar kiln. I think the deal here is you keep it in a dry, protected, well ventilated area, but with the south side glassed in.
The other disadvantage of air drying, which was explained to me, is the rot factor. Seems the softer woods such as basswood will get a bit moldy during the natural air drying process.
Nailbags 12-27-2012 09:42 AM
Build a weather shed and sticker the lumber have good air flow and let it dry. You can look up the tables for air drying by the USFS.
