Kerosene Torpedo Help Needed - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 05:58 PM   #1
kerosene torpedo help needed
i have a 150 remington torpedo kerosene heater thats not working right.
It will start when I plug it in like it should, runs about 10 seconds, shuts off with a big puff of smoke. I can unplug it and restart it, it will do the same thing? Any ideas as to what to look for ?
tecate1987 is offline   Reply With Quote
Old 01-03-2010, 06:47 PM   #2
Household Handyman
Rewards Points: 1,408
It sounds as if the unit is getting "flooded". This could be caused from either a fouled air cleaner--when have you removed it for service? And/or a faulty fuel pump unit. On the units I have worked on, the fan also operates the fuel pump and it is attached directly to the fan motor shaft in some method. IF you do not have a fuel filter in the tank, the "carburetor" can/will get particles in it which will cause it to work erratically. Cleaning the air filter is no problem, much like the foam units on most push mowers. Unless you are very mechanically inclined, removing, taking apart, cleaning, and putting the carb back together may be a challenge. There is also the chance that your has an electronic control unit which would have a "thermistor" in the system. IF SO, the thermistor could be telling the unit that it is not heating up properly, or maybe even overheating, and this shuts the system down rather abruptly, therefore---the big puff of smoke and probably the smell of half-burned kerosene. Good Luck, David
Old 01-03-2010, 07:54 PM   #3
heater
Where is the air cleaner located?
Old 01-03-2010, 08:28 PM   #4
Household Handyman
Glad I have not hung up yet and looked back at this. This will depend on maker and model so I will give somewhat of a generic answer: The air cleaner is usually located on the rear of the unit, most are inside a metal or plastic cover, some snap off, others have screws which must be removed. Most original air cleaners were of cheap foam material and will break down and crumble easily. I have used the foam replacement filter material for home window A/C units with success. At the point you are at with this unit, I would take the top cover off and check the motor unit to assure that it spins freely. IF the motor is slow at all, this will also cause an excessive heat build-up which would cause the unit to shut down by itself--over-temp. This will also be a good time to check the condition of the hoses, they are notorious for breaking down, with small cracks in them. Most of these hoses can be bought at auto supply stores in one-foot quantities. I would also suggest that if you do not have the owners/operators manual, you Google for it/them. You could probably Google and find a lot of information as to maintenance and repair of this type heater. I really like them , but they are so, so noisy. Good Luck, David
Old 01-03-2010, 08:57 PM   #5
Drywall contractor
Rewards Points: 1,070
Most tool rental places will service torpedo heaters if you're not confident working on it yourself...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-18-2010, 07:35 PM   #6
heater
It seems to be working. The filter must have been plugged. I changed the fuel filter and it started to work. I changed the air cleaner also just to do it, it didnt look to bad. THanks for the help.
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 08:15 AM
calculating amount of exhaust vents needed bitty071203 HVAC 4 06-09-2009 07:13 PM
Kerosene heating issues mikehende HVAC 23 03-29-2008 11:06 AM
Space Heater And K-1 Kerosene bobo General DIY Discussions 7 10-25-2006 10:38 PM
