Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-22-2009, 07:46 AM   #1
kerdi shower base
I would like to build a 36" x 72" shower, using the 32" x 60" Kerdi Shower Base. How to you fill in the 4" x 12" that the Kerdi is short? Do you buy the 72" x 72' and cut it???
paluch is offline   Reply With Quote
Old 09-22-2009, 07:00 PM   #2
kerdi shower base
If you are flexible on the size of the shower you could make it 42 X 72 with a 12" seat on the back and rear wall. Or you could do a 12" seat on the rear wall and a 4" seat/shelf on the back wall but a 4" seat would be useless and raising it up high enough for a shelf would make the shower seem small.
Rege
RegeSullivan is offline   Reply With Quote
Old 09-23-2009, 09:00 AM   #3
gravity always wins
kerdi shower base
That's what I did, bought it large. Located the drain and then sawed it to size on a table saw. The drain on mine is offset slightly to miss a floor joist. It's a great system.
Old 09-23-2009, 09:04 AM   #4
kerdi shower base
Mud it.
R&D Tile is offline   Reply With Quote
Old 09-23-2009, 09:08 AM   #5
ccarlisle's Avatar
kerdi shower base
Yup, just fill it in. Place the tray so that it is centered, then mud the 6" portion on each end.
ccarlisle is offline   Reply With Quote
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 04:46 PM
Kerdi Basement Shower ldogg Flooring 7 09-13-2009 09:28 PM
Installing a new shower base frgwtchr Plumbing 2 08-17-2009 07:30 AM
How to install a preformed shower base Ironman Plumbing 2 01-15-2009 09:36 PM
