Kerdi/redgard Over Easyboard Over 6 Mil Poly - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-11-2009, 07:19 AM   #1
kerdi/redgard over easyboard over 6 mil poly
Hi everyone,
I'm new so be gentle.
I am currently renovating my main floor bathroom and gutted everything. One of the walls is a concrete exterior wall that I want to insulate with batt unfaced insulation. What I'm planning to do is put a roofing paper first on the concrete wall then frame 2x4s, insert the batt then put the poly. I bought some 1/2" Easyboards and planing to put Kerdi for waterproofing. Is Kerdi over Easyboard over the 6 mil poly okay? Since Kerdi also acts like a water/vapor barrier then it's like sandwiching the Easyboard in between 2 barriers and some say it's not good.
What do you think?
I'm up here in Canada.
bhoyie is offline   Reply With Quote
Old 09-12-2009, 08:44 AM   #2
Remodeling Contractor
never have two vapor barriers. Having any vapor barrier against the concrete wall is a no-no let alone two. No poly, no tar paper. Leave a 1" space between the concrete and the studs to allow the wall to dry when needed. Use 2" foam panels against the concrete.
Old 09-12-2009, 12:33 PM   #3
Registered User
Rewards Points: 5,498
http://www.buildingscience.com/docum...gs?full_view=1
Be safe, Gary
Old 09-14-2009, 12:03 PM   #4
Thank guys...
I will just do rigid foam (I can only find 1 1/2" from local HD) then 2x3 wood studs (to save space) then Easyboard then Kerdi for wateproofing.
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 07:29 AM
Poly pipe couplings rtoni Plumbing 3 06-15-2009 09:53 PM
poly over poly for kitchen cabinets? vbfk Carpentry 2 03-31-2009 04:10 PM
Concrete and Poly Moisture Barrier Colby Building & Construction 5 03-31-2009 10:07 AM
Poly interior doors gregrice Painting 4 05-15-2006 12:35 PM
