Keep Wood Ceiling Under Tiles? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 11:18 AM   #1
Keep wood ceiling under tiles?
Just bought a house and noticed that there is a wood plank ceiling (4 inch wide plywood planks) underneath the old ceiling tiles. They are not tongue and groove, just planks and are in exceptional shape.
Could I just stain or paint the planks as is, or must I recover them with drywall? I would love to keep the wood and not cover but my concern is whether this will create air draft or dust issues. There is currently rolled fiberglass insulation on top of them but I may need to blow in some additional insulation as well.
Any advice or suggestions?
Drhoda is offline   Reply With Quote
Old 01-16-2013, 11:31 AM   #2
Rewards Points: 13,732
Got a picture?
And your right there will be dust, and drafts, as well as possible code issues if it truely is just old wooden boards.
Old 01-16-2013, 11:47 AM   #3
I'll try and get a picture to post.
Old 01-16-2013, 11:49 AM   #4
DIY staff
Rewards Points: 7,174
You need fire stopping---If practical---leave the plywood and overlay it with drywall---this way you won't have the mess or expense of removing the existing insulation.
Old 01-16-2013, 01:27 PM   #5
PoleCat's Avatar
Rewards Points: 1,646
I believe the question is....what is above the planks? Are they screwed straight to the ceiling joist? There may be lath and plaster or drywall there. Check before you go off on a tangent.
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
oh'mike (01-16-2013)
Old 01-16-2013, 02:08 PM   #6
I assume they are nailed to the joists with fiberglass insulation directly above them. Haven't been up in the attic yet to investigate.
The Following User Says Thank You to Drhoda For This Useful Post:
Old 01-16-2013, 05:49 PM   #7
Rewards Points: 744
Just curious...Did you get a home inspection before purchasing?
Seattle2k is offline   Reply With Quote
Old 01-16-2013, 06:55 PM   #8
Rewards Points: 278
One thing I saw on tV about a wood ceiling is that when combined with the wood floor above and if there is air space in between it will act like a subwoofer and amplify the sound of footsteps in the floor above. People that want a wood ceiling are advised to put accoustic insulation in the space between the floor and ceiling.
Jim F is online now   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
Old 01-17-2013, 04:45 PM   #9
Thanks PoleCat. I want and checked today and it appears there IS drywall or some similar type barrier between the wood and the joists. So it appears like I habe both a fire and air barrier as well as something to keep the dust from the attic....
My current thinking is to just spray paint it white. Ceilings are only 8 foot so I think leaving them natural will make the room look smaller?
Old 01-17-2013, 04:47 PM   #10
Hell I only gave $23,000 for the house. I buy these kind of distressed properties....pretty much assuming the worst.
oh'mike (01-17-2013)
Wood Ceiling panels discolored from Track Lighting DIY808 Carpentry 2 01-03-2012 06:11 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Colloquial Wood Tiles survivor122 Flooring 2 04-01-2009 08:29 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Hanging Drywall over ceiling tiles bjorgens Remodeling 4 12-19-2007 12:59 PM
