#1 |
joint compound question
Newbie here asking a question for an older relative who isn't web saavy.
Can you use joint compound instead of plaster of paris, on plaster walls? Thanks. |
#2 |
Paperhanger/painter
Yes and no.
Its Ok for thin repairs, skim coats, etc. If its a major hole, or deep, a 'setting' type compound would be recommended.
ProWallGuy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Contractor
Pro, don't you use the setting type for everything? Air dry is on the top of my aggravation list.
#4 | |
Paperhanger/painter
joint compound questionQuote:
| Display Modes | |
| premix joint compound vs setting type | ITE | Drywall & Plaster | 23 | 03-17-2012 12:18 PM |
| Plaster to drywall joint question. | ERIK2173 | Remodeling | 7 | 05-16-2009 05:58 PM |
| Ball and Socket Joint Question | lateralan | Carpentry | 9 | 04-25-2008 10:12 AM |
| Teflon tape or teflon pipe joint compound? | zel | Plumbing | 1 | 04-02-2007 10:54 PM |
| What brand of Joint Compound? | mwehnes | Building & Construction | 6 | 03-26-2007 08:11 PM |
