Joint Compound? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-05-2008, 03:54 PM   #1
enrico1223's Avatar
Question
joint compound?
I am doing a repair at the edge of the bath tub, no matter how hard you try the corner is always going to get wet, I have to put some joint compound at a repair seam, QUESTION: what brand joint compound is the best for bathroom and or high humidity projects? or does it make a differance?
2nd. what would be the best primer and paint to complete the work.
enrico1223 is offline   Reply With Quote
Old 03-05-2008, 07:38 PM   #2
General Contractor
joasis's Avatar
Have you considered a tub surround? Buy a ready made one at a box store or consider tiling the surround. If any drywall is exposed to water, either directly, or indirectly, it will not hold up....the plastic and fiberglass tub surrounds are a piece of cake to install. Then, use a bathtub caulk to seal around the edges.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 03-05-2008, 08:39 PM   #3
An old shoemaker's trick was to use auto body filler, the kind where you mix the filler with a creme hardener. Tough to sand, but once it's sanded smooth, it is very strong and it does survive getting wet. However, the wallboard area it's applied onto can't get wet or else it will simply peel off of it like a scab off of a wound.
There are better solutions to your problem but nothing that's cheap or easy.
End Grain is offline   Reply With Quote
Old 03-05-2008, 08:42 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You could also use a more pliable material: It is much easier to work with, than bondo: http://www.minwax.com/products/woodm...ood-filler.cfm
The materials are essentially the same.
Seal the edges and all other connected edges with paintable silicone.
Paint with a proper exterior grade primer and top coat.
- Build Well -
Old 03-06-2008, 08:39 AM   #5
enrico1223's Avatar
joint compound
I want to thank those that responded, all the ideas are usable, but the one I chose and didn't think of myself, being in the automotive industry, was using BONDO, what a great idea!!!
Thanks again.
Old 03-06-2008, 10:54 AM   #6
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Body filler is a great idea, but Bondo is junk. Try to find a better brand and make sure it hasn't lived out it life on the shelf. Auto body and marine supply stores should have fresh ingredients. Sanding is best when in the "green stage," just before it hardens to rock-solid.
Another alternative that I've been having good luck with is vinyl patch. I loaded this stuff in a gap that it would have been too much trouble to match the cut with drywall and it hasn't cracked yet. (knock on head)
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
spackle versus joint compound... joeyboy General DIY Discussions 13 01-06-2016 05:09 PM
wallpaper over fresh joint compound Joe71 Interior Decorating 6 02-25-2008 06:43 PM
Joint Compound Vs. Spackle Rze Painting 5 09-14-2007 11:09 PM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 09:54 PM
What brand of Joint Compound? mwehnes Building & Construction 6 03-26-2007 07:11 PM
