Joining A VERTICAL 1" Pipe To Horizontal 1" Pipe (without Drilling) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-20-2013, 12:18 PM   #1
Chief Pixel Pusher
Joining a VERTICAL 1" pipe to horizontal 1" pipe (without drilling)
I am trying to figure out the right kind of clamp to use on a Yakima Bike rack, which will save over $100 bucks a set on something similar to this:
I need to somehow connect 1 vertical pipe to the bar across the top of my car which is 1" in diameter. I do not want to drill a hole as that will weaken the bars. Any ideas on clamps that may work?
javapop is offline   Reply With Quote
Old 06-20-2013, 12:24 PM   #2
MarginallyQualified
Rewards Points: 2,464
http://www.keeklamp.com/
Old 06-20-2013, 02:15 PM   #3
Rewards Points: 1,428
I've seen some like these that don't require drilling. Not sure where to get them though.
http://www.simplifiedbuilding.com/st...ocket-tee.html
mikegp is offline   Reply With Quote
Old 06-20-2013, 02:23 PM   #4
Chief Pixel Pusher
Thanks guys, these are still a little expensive. I did see this idea using copper connectors. They never finished it, so I'd have to register and ask the guy I guess!
Old 06-20-2013, 02:59 PM   #5
Rewards Points: 6
Copper is soft and will bend under stress, especially those fittings since they are cut in half. I'd bet he finished but it failed. IMO, $100 for the rack is a good investment as you know it will work with your existing bar. Think of the cost if your homemade solution fails and your kayaks go flying off the roof of your car possibly hurting someone else.
Dan
djlandkpl is offline   Reply With Quote
Old 06-20-2013, 03:09 PM   #6
Chief Pixel Pusher
Good point! This is a DIY forum though.... although I do want to have a safe solution, and save some money of possible!
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
One (1) 1 1/4" gas pipe v.s. two (2) 1" gas pipe, which is better? pttcc Plumbing 7 02-16-2010 11:45 AM
What is Best for Joining Polyethylene Pipe Insulation? fritzycat1 HVAC 1 09-18-2009 03:52 PM
How to add a tee into a vertical pipe? Mechelle Plumbing 9 09-29-2008 01:59 PM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 07:47 PM
