Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-02-2009, 05:58 PM   #1
Unhappy jimbobrew
I have 4 louvered roof vents (about 4" high) on my 4:12 roof, strung out just below and along the ridge. I have soffit vents between every other truss in the 2' wide soffit. Last winter I had an accumulation of over 3 to 4' of snow on the roof for the most of the winter. This covered my roof vents, and icicles starting building up on most of my soffit vents. Since the roof vents were covered and useless, I am thinking of installing louvered vents at the ridge on each gable end. Will this work? Also I seem to get more icicles on and below the fascia than my neighbors. Any suggestions here?
jimbobrew is offline   Reply With Quote
Old 11-03-2009, 10:37 AM   #2
Do you have enough insulation in your attic? Is the hatch to your attic insulated?
Just a few things to check.
gma2rjc is offline   Reply With Quote
More On This Topic
Learn how to adjust the truss rod to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
If you're living in a mobile home and facing your first winter, you may not be aware how difficult it can be to keep a mobile home warm. Taking the proper steps to winterize your mobile home cannot only help keep you warm, but keep your heating bills... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be checking the flashing and resealing all seams. You want to make sure that you check all of the flashing around all of the vents, the fireplace and any other protruding objects or... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
