Which Items Would You DIY? Which Would You Hire Out? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 03:07 AM   #1
Rewards Points: 41
Which items would you DIY? Which would you hire out?
So, I get the keys to my new house tomorrow. First one I've owned!
Here's the list of things (so far) I've considered doing or having done in the first year. I'm fully aware I can't do them all, but I want to do some of them - more for the fun and satisfaction of doing them than to save money. Though I don't mind saving money, either. The list is in rough order of priority - the things at the top are ones I consider more important to get done sooner.
If you had this list, which things would you do yourself, and which would you hire out? And why?
  • Fix bathrub drain leak
  • Fix jacuzzi tub PVC joint leak
  • Fix running Toilet
  • Drywall garage interior walls
  • install garage door opener
  • Install reverse osmosis filter in kitchen
  • Replace/repair damaged crawl space screens
  • Paint garage interior
  • Repair / replace mater shower door that doesn't close at the top
  • Replace ugly glass around guest bath showertub door with curtains
  • Elastomer coat the garage roof -- before el nino hits this winter!
  • Run ethernet - stopgap to offices to get the two non-wifi computers online.
  • Fix pipe/faucet vibration in hall bath faucet
  • Add ground wire to jacuzzi pump
  • Run non-softened water line to back of house (copper pipe, run through crawlspace, about 70')
  • Add shelves to master closet
  • Replace kitchen sink
  • Hang sliding closet doors in guest room
  • Paint the house & garage exterior
  • Sandblast/strip paint off the front stone facade. (Someone covered the pretty natural granite with white paint!)
  • Sprinklers / irrigation in front yard
  • Sprinklers / irrigation in back yard
  • Landscaping -- xeriscape front yard
  • Repair damaged joint in A/C ducts
  • Replace carpet with wood floor in the two offices
  • De-squeak hardwood floors
  • Run ethernet - done properly to most rooms with wall panels
  • Tile the kitchen floor
  • Epoxy coat garage floor
Thanks everyone!
IdahoEv is offline   Reply With Quote
Old 08-28-2012, 05:15 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
They make wi-fi adapters like this that you just plug in to the computer and it connects, no wires. As to the rest, I would probably tackle most except plumbing and carpentry and probably what ever you were doing on the roof
http://www.outletpc.com/gc5492.html?...FUfd4AodeGYADQ
Old 08-28-2012, 07:12 AM   #3
Rewards Points: 3,130
I would do (and mostly have done) all of them except the sandblasting.
Old 08-28-2012, 07:25 AM   #4
As a remodeler for 27 years, I have done it all at one time or another. I used to do electrical on a friends license, but now I sub that out. Most localities allow the live in owner to do their own electrical, but it must still be inspected. Some plumbing I do, but leave drains to the experts. I don't do concrete, it is not a one man job!!!!!
There is very little I can't do or won't try. Wisdom often dictates otherwise.
Old 08-28-2012, 07:28 AM   #5
bbo
i'd sell and get a new house
kidding .. kidding ... i would probably try to tackle them all, though I would consider a plumber for all the plumbing related ones. you might be able to get him to to them all in one trip.
ooh and I'd get someone to go on the roof.
bbo is offline   Reply With Quote
Old 08-28-2012, 08:09 AM   #6
Too Short? Cut it Again!
Beyond whether you could or should do any or all of them is being honest about how much you have to budget in terms of time and money---and learning curve. There is nothing worse than oodles of started projects that never seem to get finished.
You also need to "triage" your list to see what has to happen quickly and what can wait. Then again, do the exercise in paragraph one. Are you going to be able to get to the membrane roof in time? Can you live without painting the garage?
Old 08-28-2012, 09:11 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
You got enough there to keep a feller busy for quite some time. The leaks warrant immediate attention but the rest of that stuff you can address whenever you get around to it. When we got our dilapidated house almost twenty years ago I had ambitious plans too. But rather than go charging in I let the ideas mature over the course of several years and saved a lot of time and money not doing things that would have turned out being a waste.
PoleCat is offline   Reply With Quote
Old 08-28-2012, 09:13 AM   #8
bbo
I need to tell the wife that when she asks ... "Let's let that idea mature while we finish all the other crap."
of course, i'm the one who likes starting projects though.
Old 08-28-2012, 09:23 AM   #9
PoleCat's Avatar
I am blessed with a wife that has nearly infinite patience. Were it not for that I would have been swiftly painting walls that were to be torn down and putting a 6th layer of shingles on the roof and , and, well too much to mention here but I understand the delima of a demanding spouse. My cousins wife went off the deep end on one of his projects and went through the house with a hammer knocking holes in the walls everywhere.
Old 08-28-2012, 06:00 PM   #10
chrisn's Avatar
Rewards Points: 234
nice
Old 08-28-2012, 06:10 PM   #11
Rewards Points: 2,516
If I had that list of repairs/projects on a home I'm taking possession of tomorrow, I'd be hoping the purchase price of the home reflected that list.
hammerlane is offline   Reply With Quote
Old 08-28-2012, 06:11 PM   #12
Rewards Points: 2,238
Do the plumbing leaks first.
Kitchen sink? - think about a new faucet.
Post a separate thread in the "Electrical Sub-Forum" concerning a
ground-wire on the Jacuzzi.
"RF"
rossfingal is offline   Reply With Quote
Old 08-28-2012, 06:39 PM   #13
In a little over my head
Rewards Points: 706
I would most likely attempt most of it myself, because I'm that way. But, I've learned a few things along the way. I don't really like painting and drywall. And, hanging drywall is easier with two people. If I have to ask for help, I might as well hire someone who's good at it. (I don't like drywall anyway) My wife seems to like painting.
I think plumbing is a good skill for a homeowner to have. Start with easy, non critical things. Like the toilet that runs. Next time you need a plumber, it may be late Sunday night. That's when your plumbing skills are really valuable. And I think plumbing is kinda fun, even if every project does take three trips to the store.
IMO, a roof is what makes a house a house, and not a fancy courtyard. So spreading roof sealer is your first project, and it's an easy one. Just wear old clothes. Find a local roofing supply house, instead of the big orange box.
There really isn't much on the list beyond the scope of DIY. It's not all gonna happen in one weekend. And a few of those items are hardly critical. But you'll be surprised what you can do once you pull on your overalls and decide to get dirty.
ratherbefishing is offline   Reply With Quote
Old 08-29-2012, 01:25 AM   #14
Rewards Points: 324
I'd do all except the electrical & maybe the copper pipe. Knowing how to do basic plumbing is a godsend; while staying at a friend's house while doing a job in another city, one evening the toilet decided to leak all over the floor, just as I was about to head out the door to the nearby kendo club.. I was the only one in the house who knew what to do - I shut off the tap beside the cistern & dealt with the water everywhere; the next day I replaced the inlet valve. Problem fixed for $40.
mgp roofing is offline   Reply With Quote
Old 08-29-2012, 11:53 AM   #15
Rewards Points: 41
As it turns out, the price per square foot we paid is very low for this neighborhood. Most the houses around here are classic teens and 20's bungalows that have been heavily upgraded with very modern interiors, and ours is 1960's house with a 90's addition and only medium level upgrades.
That said, it actually needs very little - the electrical is in great shape; fully updated during the 90's addition with a 200 amp main and all new copper wiring. The main roof is only 5 years old. The garage roof is older and not as high quality, but still probably fine for another 5.
The only thing it really *needs* is to repair two slow plumbing leaks and fix one banging pipe. Everything else on my list is a voluntary upgrade. For example the garage would look nicer if it were drywalled, and I'd like to change the exterior color. The carpets are fine, I'd just prefer to put in wood in the room I'm using as an office, for example.
Not DIY Related: So hard to hire drywallers Knucklez Off Topic 11 08-17-2012 08:58 PM
Try things myself or hire a plumber? Puzzles Plumbing 9 04-22-2011 07:30 PM
My Dilemma: To Hire a contractor to do Everything, or Hire individual tradesmen; Headhunting55 Off Topic 4 08-26-2010 11:06 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 02:23 PM
Hire Designer Or Not for Basement? KUIPORNG General DIY Discussions 4 04-22-2010 12:30 PM
