Internal Garage Fire Barrier - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 01:37 PM   #1
Rewards Points: 156
What's up everyone. I have a 2 car internal garage and right now it doesnt have a ceiling. I was thinking a drop ceiling might be better for this situation b/c if I did drywall I'd be putting in quite a few access panels for J-boxes and valves (gas and water). I also know that you need a fire rated ceiling b/t the garage and living space (at least I think so).
Would a drop ceiling satisfy this requirement or should I use the drywall?
Branden is offline   Reply With Quote
Old 02-11-2011, 02:14 PM   #2
Fire barrier garage to living space
When or house was built in 96 the contractor used fire core drywall between the house and the garage. When I finished the room upstairs I used same fire core drywall on the ceiling, can't see how a dropped ceiling would fill the bill. I was told that even the I beam spanning the garage required boxing in by today's standard. Suggest you call local building inspector, have found them to be most helpful.
ran139 is offline   Reply With Quote
The Following User Says Thank You to ran139 For This Useful Post:
Branden (02-14-2011)
Old 02-11-2011, 02:46 PM   #3
Registered User
Rewards Points: 526
I agree with ran134 above, pp.4; http://www.codecheck.com/cc/images/CC5thEdSample.pdf
And welcome to the forum!
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 02-11-2011, 03:59 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
If all you intend to do is to make the garage look better then a drop ceiling will do the trick. I don't think you will need a permit for that but better check of course.
If you want added fire protection and to bring it to code that is a different story. I don't think there is a such a thing as a fire rated suspended ceiling but I might be wrong on that.
Or just add 5/8" type "X" fire rated GWB to the joists, fire tape and mud.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Old 02-12-2011, 09:29 PM   #5
Rewards Points: 183
You should use drywall not just for the fire protection but also for fumes. There is noway a drop ceiling will beable to stop exhaust or gas fumes from entering your upper floors.
paul100 is offline   Reply With Quote
The Following User Says Thank You to paul100 For This Useful Post:
Garage ManCave Please Help!!! ManCaveMark Building & Construction 7 09-14-2011 03:01 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Fire rated drywall between garage and house...on both sides? RyanD Drywall & Plaster 7 06-29-2009 08:49 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Sagging sheetrock in garage cieling, need to seal it to insulate. 240sx4u Building & Construction 6 01-01-2009 05:24 PM
