Interior Door Locks All Broken? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 11:11 AM   #1
Rewards Points: 113
Interior door locks all broken?
Just moved into a rental and all the interior doors have the same kind of schlage non-key locking push button door handles.
The problem is that the handle on either side of the door releases the lock.
I took one off the door and put it together off the door with all parts as tight as they can be, and it's the same. The push button makes two metal posts protrude on either side of the main shaft, but a twist from either side makes them pop back in. It's virtually every door in the house, so I doubt they were broken.
What could it be?
wengang1 is offline   Reply With Quote
Old 09-03-2012, 03:51 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
ALL interior doors? Bedroom, bathroom, and closets?
Did you ask your landlord?
It might be intentional. Maybe he got a deal on them.
Old 09-03-2012, 07:54 PM   #3
Rewards Points: 113
I didn't ask, but I suspect it was sth like that.
I took a broken one apart completely together with the only working one, and the only discernable difference was that the two posts that protrude when the lock button is pushed are bent slightly in opposite directions whereas they are perfectly straight on the working one.
If I had to guess, it could be that somebody tried really hard to twist the outside handle open when the door was locked.
Since they were all broken, maybe he bought them second hand already like that
Old 09-07-2012, 06:27 AM   #4
custom user
Rewards Points: 150
...or previous tenants tried to fix them. You had said it was every door not working but it looks like you found a working one and found the problem.
JasperST is offline   Reply With Quote
Old 09-07-2012, 06:49 AM   #5
the Musigician
DangerMouse's Avatar
It sounds like you found some "quality" locks from (you know where) and you will need to replace them with REAL locks. The "forked" lock I bought did the same thing the first day I put it in a door that was simply snug! It does not take any force at ALL to twist the forks. Look at the lock before buying to assure the center shaft is a SOLID bar, not the forked crap.
DM
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Making a patio from broken granit slabs need help BJLower Tiling, ceramics, marble 9 09-15-2014 12:15 PM
Broken roof joist Velvis Roofing/Siding 3 07-16-2012 01:21 PM
Repairing a broken settled cement slap to repair broken tiles Dtlsr42 Flooring 0 02-20-2012 01:43 PM
Broken roof truss/support help needed please! Pictures included! MrShadetree0222 Building & Construction 3 11-04-2008 07:17 PM
