Insulation Under Attic AC Unit - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 03:30 PM   #1
Insulation under attic AC unit
I have taken on the project of adding insulation to my attic.
I am adding another R-30 layer on top of my R-19. My attic is complicated, considering the AC unit (located on floor joists) and duct work (on floor joists) extend down much of the center (approx 95 sq ft). While I will be adding the R-30 throughout and close to the AC unit, I will not be able to fit any significant new height of insulation underneath the AC unit or ducts. R-30 is like 10" high. I probably have 4" underneath the unit.
So, I had the idea to use a 2" rigid insulation under the unit. Adding an additional R-10 at least. I learned that this is not safe with the fire hazard limitations of rigid foam. I thought about adding it only to the duct work areas - not AC radiant heat areas. I just hate to do the project but leave a huge area with only the R-19 in the middle. Is there a way of adding the rigid foam safely? I have read the drywall enclosure concept for walls, but this may be too difficult.
Could drywall glued on the foam be a legitimate safety precaution? Any suggestions? Thank you - Nick
nickelshine is offline   Reply With Quote
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 11:19 PM
Attic Insulation paige2 General DIY Discussions 21 03-16-2011 11:35 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
Insulation in Garage Attic ? SaDan Building & Construction 2 05-09-2010 06:44 AM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 10:41 AM
