Insulation Touching Concrete In Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-22-2010, 12:12 AM   #1
insulation touching concrete in basement
Im framing my walls in my basement, the exterior first.Im useing metal framing and i want to 2 1/2 studs to give me more sq footage.My question is if i do that and leave myself some space behind for clearance,then use 3 1/2 batt insulation it will touch the concrete,im thinking that will be a problem in the long run.
THX
ron0805 is offline   Reply With Quote
Old 02-22-2010, 10:09 AM   #2
You do not want the fiberglass insulation touching the basement walls
Ideally you want 1" of air space behind the insulation
Or use rigid foam boards up against the basement walls...then studs
Old 02-22-2010, 01:49 PM   #3
Drywall contractor
Rewards Points: 1,070
And by compressing the 3-1/2" insulation into the 2-1/2" cavity you would actually lose R-value....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-22-2010, 02:13 PM   #4
Just curious, why is it a problem if the insulation touches the basement floor?
seawiz is offline   Reply With Quote
Old 02-22-2010, 10:37 PM   #5
You might want to read this before you get started. I would NOT use fiberglass! You will just end up with mold!
http://www.homeconstructionimproveme...#comment-36170
http://www.eere.energy.gov/buildings...s/db/35017.pdf
soasquad is offline   Reply With Quote
Old 02-23-2010, 12:25 AM   #6
Registered User
Rewards Points: 5,216
"use 3 1/2 batt insulation it will touch the concrete,im thinking that will be a problem in the long run." ----- correct: http://www.swinter.com/services/docu...Insulation.pdf
http://www.buildingscience.com/docum...gs?full_view=1
No air space behind the insulation: http://oikos.com/library/insulating_...lls/index.html Glass batt relies on the small air spaces to work properly. A bigger space allows air currents to form defeating the whole idea of still air. AND, fire-stopping is required every 10' horizontally and vertically, per safety code.
Be safe, Gary
Basement Insulation and humidity control mcwolfe6 General DIY Discussions 11 01-28-2010 07:02 PM
Basement insulation lenkaj General DIY Discussions 2 01-19-2010 08:38 PM
Insulation for Concrete Basement Walls soundman79 Building & Construction 8 07-15-2009 02:54 PM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 05:56 PM
insulation b/ween concrete and gravel in live-in basement amakarevic Building & Construction 6 08-15-2007 01:02 PM
