Insulation On Top Of Old Roof Deck??? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-30-2008, 02:22 PM   #1
Question
Insulation on top of old roof deck???
I recently had a new pitch roof built over our previously flat roof. The old shingles were torn off, leaving just the deck, and the new roof built over top, leaving new attic space. I do not have adequate insulation under the old deck so I want to add insulation.
I would like to do it my self, but I am leary of blown in insulation. Everything I read seems to suggest having a professional install it. If went with rolled insulation can I just roll it right on top of the deck?
Thanks,
ubie42 is offline   Reply With Quote
Old 12-30-2008, 03:11 PM   #2
joed's Avatar
Rewards Points: 11,632
I don't see why can't just add it on top of the old deck.
Old 01-01-2009, 01:23 PM   #3
I had a house with a floor in the attic. The joist bays were filled with rock wool insulation! I installed fibreglass bats by laying them on top of the wooden floor! I never encountered a problem with this and I was quite happy with the reduction in the fuel bills! Your situation is similar to this, and I would expect that insulation on top of the old roof deck would be effective!
Old 01-01-2009, 01:51 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
unfaced insulation?
Tom Struble is offline   Reply With Quote
Old 01-01-2009, 01:55 PM   #5
Originally Posted by strublesiding@optonline.n View Post
unfaced insulation?
Yes! 2X4 R20 bats!
Old 01-05-2009, 06:31 PM   #6
Thanks! I measure the current insulation and have what I believe is fiberglass...about 3.5 to 4 iches. Including the the old roof deck, what R value would you say I have? I would like to get it up to at least R-39, and if I can save a couple hundred bucks by selecting a lower R-value, I'll do it. I am little tight on cash... Also, how much is enough? Is there really going to be much of a savings once you get to R-39 and above. Do I need R-60 if R-40 is good enough?
Old 01-05-2009, 07:22 PM   #7
I would start with R20 then if you think that you would like more in a few years, put in another layer! Theres no limit, beyond space, to how many layers you can have!
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 06:37 PM
