Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-29-2005, 04:12 PM   #1
woodie
insulation question
Has anyone used strofoam board inside with sucsess,
my problem is I have an unfinished attic, and the roof suppoirts are only 2x4 (old 110 yr's old, so they are a liuttle thicker and deeper than new construction) I just want to cover the walls, and may be panel. I know I need the air flow for the roof. if I use regular insulation Ill have to build out the studs.
rservices is offline   Reply With Quote
Old 12-29-2005, 07:39 PM   #2
Remodeler
MinConst's Avatar
insulation question
Foam board is OK. You can cut and fit between the stud or apply it 4'x8' sheets to the studs. You might be better off building the rafters down another 2x2 to give you some room for R13 anyway. Not sure on the load properties as this will add to the weight of the roof. Without more snow load information it is hard to guess. Roof pitch etc.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 01-03-2006, 01:10 AM   #3
Commercial Roofing
AaronB's Avatar
insulation question
If you hire a SPF insulation cotractor, 2.8 lb foam is nearly R 7 per inch. He could install a mesh and spray onto it, keeping our attic airspace flowing form the bottom up under the roof deck.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Insulation question Outbacker HVAC 16 12-29-2008 10:54 PM
Insulation question hswaters General Discussion 9 12-28-2008 09:18 PM
Rigid insulation question Endeavor General Discussion 2 07-17-2007 11:27 AM
yet another insulation question bobbyhill Building & Construction 2 12-06-2006 01:01 PM
