Insulation On Plasterboard - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-13-2007, 02:16 PM   #1
Insulation on plasterboard
I am putting in a new bathroom upstairs.
I want to insulate the floor of the bathroom to reduce the noise heard by the people downstairs. The floor is wooden floorboards on 8inch wooden joists with plaster board nailed on the ceiling.
Can I place any type of insulation straight on the top side of the plasterboard as I don't want to take the whole bathroom floor up? Do I have to support the insulation or can it rest on the plasterboard? I need it for sound deadening rather than heat properties. Many thanks Chris
hermitage777 is offline   Reply With Quote
Old 12-13-2007, 03:52 PM   #2
As long as the plasterboard is properly secured then you should be able to put insulation there.
Is there going to be a bathtub installed?
How long are the 8" floor joists?
redline is offline   Reply With Quote
Old 12-13-2007, 04:01 PM   #3
Hi there.
No bath tub. Only a shower, Basin and toilet. I thought I could take a few floorboards up and slide the insulation along the top side of the plasterboard.
Bathroom is about 10 foot by 10 foot. What do you think would be the best light weight sound proofing material?
Many thanks
Chris
Old 12-13-2007, 04:03 PM   #4
Fiberglass insulation should be the least expensive.
Old 12-13-2007, 04:12 PM   #5
Rewards Points: 266
i blew in cellulose between the basement family room and the master bedroom. It has been a great sound deadener. Had 6 teenagers downstairs and we didnt hear anything in the master bedroom
What have I done is offline   Reply With Quote
Old 12-14-2007, 07:11 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,.....
Blown in would be Much Easier,......
Fiberglass mats don't Push very easily.........
Bondo is online now   Reply With Quote
Old 12-14-2007, 08:58 AM   #7
Does the home have copper wiring or the older knob and tube?
Old 12-16-2007, 12:26 PM   #8
I will also be looking for some "sound" insulation, and one thing I am planning on looking into is the material used in recording studios to deaden sound, rather than insulation.
As I haven't looked into it much yet, I don't know if it will be more or less expensive or if it will be more or less effective than insulation.
My guess is that in both cases, it will prove to be more, rather than less.
If you are interested in looking into this, here's a place to start your search:http://www.bhphotovideo.com/c/catego...nal_Audio.html
If you find anything interesting and/or make a decision, please report back so we can all learn from this.
thanks.
User Name is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 04:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
