Insulation For A Metal Building - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-11-2005, 11:03 PM   #1
amy
Insulation for a metal building
I have a shop that is metal and I'd like to insulate it. Are there any specal considerations or specific insulation that I should be using different from that stuff you can get at the local Home Depot?:confused:
amy is offline   Reply With Quote
Old 12-15-2005, 08:29 AM   #2
Commercial Roofing
AaronB's Avatar
Hve you considered spray foam?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-30-2006, 10:57 PM   #3
urethane insulation
I am also building a new shop. I am going to have the walls and ceiling sprayed with 4" of earthfoam urethane insulation. I am using a one pound foam which is a closed cell foam. It is also bio based and water blown instead of petroleum based. Check out www.earthfoam.com
Goodluck
jburns is offline   Reply With Quote
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
Pole Building Insulation 70RANGER Building & Construction 1 02-05-2007 08:02 PM
metal building vapros Building & Construction 2 10-01-2006 08:14 PM
kit metal building as addition structure weaver Building & Construction 9 08-08-2006 10:59 AM
