Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-19-2006, 10:27 AM   #1
Insulation material reusable?
Hi Everyone,
I removed all the half-wall insulation from the builder and framing for the basement I am building, I do not know the cost of buying new insulation and wonder should I kept the old insulation I removed from the builder, I kept them in a number of garbage bags now, but do not know if this is really necessary. Can someone tell me if those insulation generally reusable, or it does not make much sense to reuse them because of either insulation is so cheap that do not bother, or reusing them is too difficult because they no longer easily cut and paste onto the framing member nice and clean..
If the answer is no, I should not reuse them, I would rather dump those 10 or 20's big garbage bags away earlier rather than later...
Please advice
Thank You
KUIPORNG is offline   Reply With Quote
Old 06-19-2006, 01:04 PM   #2
Is this the blown-in insulation or the rolled (batts) type of insulation?
If it is the blown type you can just spread it out in the attic for addition insulation and then install new rolled insulation on the walls that you are working on.
redline is offline   Reply With Quote
Old 06-19-2006, 02:24 PM   #3
Thanks for the advice Redline... Thowing it into the roof is a good idea for energy conservation as well as save some space for our dump site for environmental sake...
Our type is pink in color... I do not know what type it refer to for your message... It is different from those on thr roof though as I visited the artic before for wiring some television cable, those on the roof is like cotton stuff which don't stick together, the type I have tore off from basement are pink in color and looks like stick together...
Should I still do that?
Old 06-19-2006, 02:58 PM   #4
It sounds like you have the rolled (batts) type and you could reuse it in the walls if it is still in good shape.
If it is not in good shape then you can still use it in the attic and buy new insulation for the walls.
It sounds like you have blown-in (loose cellulose) insulation in the attic.
Old 06-19-2006, 03:38 PM   #5
Thanks again Redline, I think it may be hard to reuse those insulation, but I will try now that base on your suggestion, if it end up too difficult, I will throw them to the roof.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Rigid insulation question Endeavor General Discussion 2 07-17-2007 11:27 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
What roofing material is right for me? Grumpy Roofing 0 07-07-2004 08:41 PM
